Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Grounding Issues
Grounding Issues
Old 25th June 2003, 08:30 PM   #1
PaulHilgeman is offline PaulHilgeman
Account Disabled
Default Grounding Issues
I am in the process of building some gainclones and a preamplifier. I am having some grounding issues.
My preamp, all 4 amplifiers and power supply are housed in separate chassis.
When I touch the center of an RCA plug that is plugged into an amplifier to the chassis of the preamp, I get a buzz. If I measure from the chassis of the preamp to the air, I get about 5 Volts AC.
When I have everything plugged in, it sounds fine, there is no hum or buzz at all. I would like to get rid of this though as to protect my speakers when I turn it on.
I have nothing connected to the earth connection on my power inlet. When I connect the earth connection to the grounds, the buzz only gets louder.
Enclosed is a schematic of the inside of my power supply.
I am an EE, but I just graduated, and we never really went into anything about grounding issues or ground loops in any of my classes.
I apreciate your help.
Thanks,
Paul Hilgeman
Old 25th June 2003, 08:40 PM   #2
future is offline future  Brazil
future's Avatar
Send a message via ICQ to future Send a message via AIM to future Send a message via MSN to future Send a message via Yahoo to future
Are the filter capacitors in each amplifier? They arent in the schematic...
And why the grounds of preamp and amp are separated?
I think this way the return will be the shield of your interconnections.
what?
Old 25th June 2003, 08:51 PM   #3
Account Disabled
Yes,
I put the filter capacitors in each of the amplifier boxes.
I dont know why I dont have them connected.
You are right, that way, the only way that the two would be connected would be through the black wire in the interconnect.
I will give that a shot.
Thank you.
What do I do about the earth connection on my AC Inlet Filter?
-Paul
Old 25th June 2003, 08:58 PM   #4
future's Avatar
In electrical equipment the AC ground is connected to the chassis, I dont know if PSU ground is tied together with AC ground.. I would let the grounds separated.
what?
Old 25th June 2003, 09:22 PM   #5
daatkins is offline daatkins  United Kingdom
I connect the mains ground (earth) and circuit ground togeter with a resistor and parallel cap network to break any ground loops between sources. You can find details here:
http://headwize2.powerpill.org/proje...meier3_prj.htm
Nice one,
David.
Old 26th June 2003, 09:36 AM   #6
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Grounding Issues
can't undersand the use of two rectifers d1,d3 when one should suffice.....
Grounding IssuesHide this!Advertise here!
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
Grounding Issues Bonce Chip Amps 18 9th June 2006 05:00 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
Grounding issues miguel2 Chip Amps 5 24th May 2004 06:55 PM
