Help with Ceramic Disc Capacitor Numbers - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th June 2010, 01:15 AM   #1
Default Help with Ceramic Disc Capacitor Numbers
I need to replace this can someone please tell me what I am looking for and where I can buy a replacement. I think this is a disc capacitor. Here is some info, this is attached to an On/Off switch on a Console Stereo, the stereo should turn off when in the Off position but it stays on. The Console stereo should when switched to the Off position turn off BUT if you turn the switch the turntable knob to On the whole unit should come on until the record finishes then the unit will turn back off automatically. So Iam thinking this has something to do with that function. Anyone have any ideas on that? Please see the photos attached. Thanks
File Type: jpg Screen shot 2010-06-29 at 5.55.46 PM.jpg (25.8 KB, 63 views)
File Type: jpg Screen shot 2010-06-29 at 5.39.51 PM.jpg (39.4 KB, 62 views)
File Type: jpg Screen shot 2010-06-29 at 5.22.03 PM.jpg (33.5 KB, 62 views)
Old 30th June 2010, 07:00 AM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
Hi
It is a 10nF cap. It has to be rated for direct across-the-mains connection, could be a "X" or "Y" safety type (the ones that carry "UL" and and marks).
If you want to avoid too much stress on the capacitor and contacts, you could add a 22 ohm/1W resistor in series.
Old 26th September 2016, 08:58 AM   #3
Hi, I think I have the very same problem. A disc capacitor put on output leads of the main transformer feeding a bulb to signalling operation state. It is soldered on a Bose 901 series IV equalizer board and I need to replace it. Can you help me with proper voltage and farads? Thanks
http://drive.google.com/file/d/0B7EN...w?usp=drivesdk
Old 26th September 2016, 06:54 PM   #4
Welcome is offline Welcome  France
Welcome's Avatar
4.7 nF
Lots of volts.
Use any 4.7 nF X2 film capacitor.
Is this a ceramic capacitor - help identify hafp Parts 2 24th March 2009 06:51 PM
Flat round and old ceramic disc capacitors AndrewGM Parts 1 6th October 2008 10:19 PM
ceramic capacitor zahlm Parts 0 18th June 2004 08:43 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
100n ceramic disc capacitor markkanof Solid State 7 20th June 2002 09:46 PM
Copyright 1999-2017 diyAudio
