Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
how did i break my secondary?
Old 25th June 2003, 07:41 PM   #1
travis is offline travis
Send a message via AIM to travis
Default how did i break my secondary?
its supposed to be 18V from orange to yellow, but its measuring like 10. brown and red are working ok -they say 20.2.
last night i had orange and red hooked together and being my 0V. brown and yellow going to the ACs of the rectifier chip thing. twas working. there's a 1A fuse on the mains. shouldn't it blow up before i hurt my transformer?
donuts
Old 25th June 2003, 09:33 PM   #2
i HATE LAQUER!
donuts
Old 8th July 2003, 01:51 AM   #3
Ilianh is offline Ilianh  Canada
Ilianh's Avatar
Send a message via MSN to Ilianh
That has to be the funniest thread ever....
Sorry, but the
"i HATE LAQUER!"
comment is just too funny, I can imagine you after 5 hours trying to get it off, sitting furious on your pc, and going to diyaudio.com to type this, not even caring about your capslock.
Time is the best teacher; unfortunately, it kills all its students
Old 9th July 2003, 05:51 AM   #4
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Well, lacquer is to be hated at times. However, without it, transformers wouldn't survive for long.
How long was this setup working before it fried? Did you check the rectifier to see if it shorted? Also, did you have a cap in backwards on the PSU??? What's the voltage of the caps used?
It seems like something worked barely for a while and then broke down thus shorting the transformer...
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 9th July 2003, 05:58 AM   #5
it works now guys. i had just cut the wires shorter and forgot that i had to scrape more lacquer off.
donuts
Old 9th July 2003, 06:03 AM   #6
Duo's Avatar
hahahahaha. You really are having a bad time with that lacquer aren't you???
Yes, you have to be scrupulous about removing the lacquer for a good connection. I usually will spend a good 20 minutes preparing a transformer's leads before installation in a new amplifier. If I'm working on a transformer with more than 20 leads, I might spend over an hour.
how did i break my secondary?Hide this!Advertise here!
Break in wicked1 Tubes / Valves 0 18th February 2008 08:30 PM
break subwoofer amanmahadeshwar Chip Amps 6 4th June 2007 07:21 PM
Sub Break In CARTRulz Subwoofers 16 4th September 2006 04:40 AM
How to break-in a new GC TheDriver41 Chip Amps 15 21st October 2004 05:34 PM
Never want to break a tap again? Nut inserts! Doh Parts 6 4th December 2003 08:15 PM
