Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th June 2010, 07:37 PM   #1
moss99 is offline moss99  United Kingdom
Default help with resistor
Hi all i am having trouble id ing this resistor i think the colours are white,orage,pink,red res (1632 x 920).jpg
thanks
Old 25th June 2010, 08:04 PM   #2
it could be red red orange silver
22k 10%
can you find a similar one in the circuit and measure it.
red = 2
org = 3 or x 1000
silver = 10%
so 22000
Old 25th June 2010, 08:18 PM   #3
hi thanks for the reply i found another and that is blown too i think i have found a schematic but not too sure how to use it the resistor location says c531 and the other one also reading open says c710
TECHNICS SU X501 SCH Service Manual free download, schematics, eeprom, repair info for electronics
Old 25th June 2010, 08:20 PM   #4
mjf is offline mjf  Austria
hello.
have you tried to measure it with a multimeter?
was the res "overheated"?
could be red violet orange............27k ?
greets
Old 25th June 2010, 08:34 PM   #5
Originally Posted by mjf View Post
hello.
greets
yes multimeter is reading open circuit
Old 26th June 2010, 04:28 AM   #6
Enzo is offline Enzo  United States
If they are called C531 and C710, then they are likely small ceramic capacitors instead of resistors. Try measuring them as caps. Red-red-orange would be 22000pf, or 0.022uf. They will measure open on a resistance reading. COnsidering what they are, I wouldn't be surprised if they were really OK.
Your schematic shows both those call numbers as 0.022uf caps. In this case both are coupling two different sections of grounds within the amp.
Old 26th June 2010, 05:33 AM   #7
Ah right capacitor ! (confusing this electronics ) well im learning,, would you mind having a look at the photo of the amp i have no sound output ,, i have tested the transistors marked with red arrows , also i have a audio signal generator but not too sure where to inject the signal to ,,would appreciate any help
Old 26th June 2010, 06:16 PM   #8
Before applying audio signals, check that power supply voltages are all present.
Old 27th June 2010, 07:10 AM   #9
hi looking at schematic on the main chip on heatsink all voltages seem right except for pin 8 which should be -.1 i have -42 and pin 9 should be -42 i have -4.2
Old 1st July 2010, 06:24 AM   #10
Above post should have said voltages on pin s on the main SVI 3204 amp chip i have removed it and have a short between pins 2 and 11 i have traced the tracks back from these pins and checked the resistors which seem ok is there anywhere else i should pay particular attention to?
I have got a new chip ordered off "taobao" !! (chinese ebay) there you seem to be able to find anything you cant anywhere else ,,
here is photo of chip the short seems to lead back to this component not sure what it is though .chip (1632 x 920).jpg
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
Why this resistor? Shel-e-bean Everything Else 28 4th August 2006 04:57 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Are you using the resistor? Ricren Chip Amps 8 16th May 2003 08:13 PM
What is the best resistor? CryingDragon Solid State 8 9th October 2002 02:38 AM
Page generated in 0.09802 seconds (78.61% PHP - 21.39% MySQL) with 11 queries
