Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th June 2010, 12:13 AM   #1
Default Can you identify this pot?
I would like to find a better quality stereo pot with on/off for a motorcycle intercom/music system I am building. I have a Radio Shack pot but fear that it is worth what I paid for it (i.e., not much). I also have the pot in the picture below from a Harman Kardon 2320V computer sound system that worked well. I'm inclined to use it but would like specs and maybe a diagram (it has nine pins). The pot I am trying to identify is the part in the foreground of the picture below with the blue band:
Thanks!!
Old 17th June 2010, 12:52 AM   #2
Sorry. I miscounted. It has eight pins - two gangs of three and one set of two pins. In the computer sound system, it controlled volume to both the speakers and the headset.
Old 17th June 2010, 01:08 AM   #3
infinia is offline infinia  United States
infinia's Avatar
dual 10K pot with on/off switch > quality is midland for consumer gear
use an ohm meter to find the center wiper/s
what specs do you need?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 17th June 2010, 03:17 PM   #4
Thanks for the response. As to specs, I just want to ensure this pot is appropriate for the application (a headset). I assume it is but would like to be a bit more certain. Also, I understand the configuration of the three pin sets. I'm uncertain as to the set of two pins - is this set to provide a fixed reference signal?
Replacing 50K pot with 10K pot KevinLee Parts 10 10th December 2007 03:50 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 09:56 PM
Converting a DACT series pot to a shunt pot Dr.H Chip Amps 9 2nd December 2004 01:55 PM
Gain pot instead of volume pot boyofwax Solid State 5 14th February 2004 02:37 AM
Page generated in 0.08000 seconds (70.47% PHP - 29.53% MySQL) with 11 queries
