Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th June 2010, 05:38 PM   #1
Default 1n4004 upgrade?
Im doing some upgrades/mods to an old Exposure integrated amp and the first thing im working on is the pre-amp section. Im going to start on the power supply which uses good quality parts but is very basic.
power trans> 4x1n4004> 2x 10,000uf/63vs> lt317/337> 10uf/50v= +/-18v
Just curious if schottky or hexfreds would be an upgrade to the 1n4004's? I also plan on upgrading the voltage regs.
Old 9th June 2010, 05:41 PM   #2
I don't see any advantage to changing.
Old 9th June 2010, 06:41 PM   #3
Thanks, what about a small .01-.1uf cap across each diode? Ive seen this done before to reduce noise.
Old 9th June 2010, 06:46 PM   #4
Unless you have a problem, don't fix it. I have been working in the field for many years and have yet to add such capacitors.
Old 9th June 2010, 08:21 PM   #5
Enzo is offline Enzo  United States
I'm with Bob here. If it works, stop fixing it.
If you want to upgrade something, I think a good place to start is to assess the areas the performance lacks, and then determine an approach to correct that. If you are getting noise, then we take steps to reduce it, but if noise is not an issue, then what's to reduce?
After some years, the electrolytic caps can start to get soft. The semiconductors just might last longer than you do. The whole point of the power supply is to provide smooth, clean DC power. So are both polarity main supplies sitting at about the same voltage? Ripple free? Under heavy load from the power amp, do they remain pretty clean? And those +/-18v rails, how do they look? are both rails at about the same voltage? Clean? In my humble opinion, it is more important the two 18v rails be the same, rather than whether it is 18v or 17v.
Rectifier vs 1N4004 argonrepublic Parts 1 3rd February 2010 08:39 AM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
the best upgrade there is Daniel-A Everything Else 0 27th March 2004 04:40 AM
Cap upgrade 5th element Solid State 2 9th March 2004 10:12 PM
Page generated in 0.07493 seconds (80.01% PHP - 19.99% MySQL) with 10 queries
