Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
is it possible to make solder flow on to 20awg solid copper with 25watt iron?
Old 22nd June 2003, 07:19 PM   #1
travis is offline travis
Send a message via AIM to travis
Default is it possible to make solder flow on to 20awg solid copper with 25watt iron?
i'm getting kind of frustrated.
donuts
Old 22nd June 2003, 07:39 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Depends on the surface area and the initial temperature.
You can easily do something about the second one...
Old 22nd June 2003, 07:41 PM   #3
hrm. how easily?
donuts
Old 22nd June 2003, 07:55 PM   #4
dhaen's Avatar
Warm it up in the oven first, take it out, then make your solder joint straight away.
Old 22nd June 2003, 08:50 PM   #5
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
20 ga is pretty thin..... a 25 watt iron should have no problem....maybe your tip needs cleaning or a new one
Old 22nd June 2003, 08:58 PM   #6
it might be 18. it flowed easy like onto the terminal for this switch, but i couldn't get it to work on this fuse holder.
i just plugged in this transformer for the first time and i didn't die.
donuts
Old 22nd June 2003, 10:25 PM   #7
JOE DIRTŪ's Avatar
also you never mentioned the type of solder you are using...I personaly use 60/40 .75 mm for power connections
Old 22nd June 2003, 10:40 PM   #8
Kermit is offline Kermit  Norway
Kermit's Avatar
Hmm, might be a long shot, but is that a transformer secondary your trying to solder? They are usually covered with some lacquer that’s not always easy so solder. If so try scraping it off with a knife.
Sven Sødem
Old 22nd June 2003, 11:46 PM   #9
60/40
.050 diameter?
donuts
Old 23rd June 2003, 12:09 AM   #10
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
ROTFLMAO.
Frustrating, isn't it?
Frank
is it possible to make solder flow on to 20awg solid copper with 25watt iron?Hide this!Advertise here!
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 04:12 PM
Reviews of the weller wes51 solder iron TeeDee Equipment & Tools 2 20th July 2006 02:01 PM
12 solid copper speaker binding posts karma Swap Meet 3 30th September 2005 03:30 AM
skin effect of a solid copper wire DUG Multi-Way 8 30th March 2003 10:38 PM
Copyright ©1999-2017 diyAudio
