Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd June 2010, 07:02 PM   #1
aptquark's Avatar
Default Gamut amp acting as a sparkler!
Hello all,
What started out as a very low hum from one channel of my D200MRKII, developed into a sparkling fireworks show later on. I took the circuit board out and noticed a SCHRACK relay had burned up internally. See pic. Nothing else looks damaged or broken on the board. I ordered a new SCHRACK relay and was wondering if this will be a simple plug n' play fix. Any comments before I fire this thing up?
Old 3rd June 2010, 10:36 PM   #2
I thought I answered this one. That relay contact is burned badly and it's probably because of a fault in the amplifier. Check that out before connecting speakers.
Old 3rd June 2010, 10:54 PM   #3
aptquark's Avatar
Bob...too late with the speakers. That side is burned out (speaker that is). Any ideas as to where I can start checking?
Old 4th June 2010, 12:51 AM   #4
Yeah those power transistors are where you start. If you find bad ones, don't stop because when they fail they take out other components.
Best to get a diagram or, at least, make one.
Old 6th June 2010, 01:24 AM   #5
aptquark's Avatar
Bob, I checked those transistors. They are MJE340's and MJE350's (NPN and PNP respectfully.) They measure like they should with a diode check (about .680 with the correct orientation and open across the rest.) Any other ideas?
Thanks in advance
Old 6th June 2010, 02:11 AM   #6
Measure the voltage from the amplifier output. It should be zero. If it is, there is either an intermittent failure or some strange transient melted your relay contacts.
You need to make sure the amplifier output is zero with no signal, and that the idling current is about right. If it all checks out, you can replace the relay but I'd add a fuse in series with the speakers in case this happens again.
Old 29th June 2010, 11:11 AM   #7
aptquark's Avatar
Fellas,
Quick question...see those transistors in the pick? Do those need non-conducting thermal paste when mounting? ALSO...the HUGE MOSFETS that the Gamut uses (2 per side)...do those also need the same type of paste?
Old 17th September 2011, 02:43 AM   #8
Default Solve problem ?
Does your problem had been solve ?
If not, I have service manual and wiring diagram to help you.
Reimyo KAP-777 as same as D200I, too
Marcus
My amp is acting like a transducer!? audio_moksha Tubes / Valves 9 15th March 2008 06:04 PM
FS:GAMUT D200 MKIII clone fully assembled & tested ANALOG GUY Swap Meet 0 31st July 2007 08:09 AM
UcD400 listening vs. Halcro & Gamut Alfetta87 Class D 26 13th February 2007 04:21 PM
Im testing my leach amp and its acting funny frckid Solid State 3 19th February 2006 10:04 AM
gamut amp brian t Solid State 1 10th August 2002 11:37 AM
Page generated in 0.10007 seconds (76.66% PHP - 23.34% MySQL) with 11 queries
