Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st June 2010, 05:36 AM   #1
mtl777 is offline mtl777  United States
Default Help ID WNC(?) cap
Does anybody know the manufacturer and series of the cap pictured below? It's a 100uF 25V electrolytic and I can see WB which is probably the series and WNC which is probably the manufacturer but I'm not sure. A link to the manufacturer's web site or a datasheet of this cap would be most appreciated. I'd also like to know if this cap is any good for use in the signal path.
Thanks!
Old 1st June 2010, 06:39 AM   #2
Mooly's Avatar
Trying to make the symbol out,
Samwha Electric - Your Future is with Us
Caps are so cheap if you are not sure just but something of known origin.
A simulation free zone. Design it, build it, test it.
Old 1st June 2010, 06:13 PM   #3
So it's a Samwha! Thank you so much!
Yeah, actually I already replaced it with a Rubycon ZL. I was just curious about it. Are Samwha caps known to be good quality? I'm wondering because I found it in a high-end ADC unit. Not a likely place to be for a mediocre cap, but maybe the manufacturer was trying to cut cost and the cap is good enough that not many people will notice a difference.
Old 1st June 2010, 06:25 PM   #4
Mooly's Avatar
Samwha are a big player, and I wouldn't like to say yea or nay as to how good they are.
They wouldn't be my first choice... but I'm basing that on having worked in the repair trade and seeing a lot of Samwha caps as standard fitment. Often in those cases it's improper circuit design that causes failure so I won't commit on that.
I quite like Panasonics and Rubycons... there what I always order.
Old 1st June 2010, 07:18 PM   #5
Thanks! That's enough of a reason for me to replace them.
I was choosing between Panasonic FM and Rubycon ZL for this position (audio signal coupling). Which one would you have preferred?
Old 2nd June 2010, 06:10 AM   #6
Mooly's Avatar
I'm sure if you do a blind listening test you wouldn't tell them apart
For small signal stuff I like Panasonics, the ECA series, partly because I can get them locally,
PANASONIC|ECA1VAM101X|CAPACITOR, 100UF 35V | CPC
If I feel a 105 degree rating is more appropriate I go for these,
RUBYCON|35YXF100MY0811.|CAPACITOR, RADIAL, LOW IMPEDANCE | CPC
Old 2nd June 2010, 05:51 PM   #7
Oh these are "for audio" caps. Nice! I wonder, how do they compare with Elna Silmic or Nichicon Muse? I've heard big praises for Elna Silmic but the only problem is its size, too big to fit most of the time when replacing existing caps. If these Panasonic ECA are as good sounding as the Silmic then they are a great find!
Why not the ZL which has lower impedance and higher ripple rating than YXF? For example, for 100uF 25V, ZL has 0.13 Ohms impedance and 405 mA ripple whereas YXF has 0.4 Ohms impedance and 250 mA ripple. For 100uF 50V, ZL has 0.074 Ohms impedance and 724 mA ripple whereas YXF has 0.25 Ohms impedance and 400 mA ripple. The dissipation factors of ZL and YXF are the same across all voltages though.
Old 2nd June 2010, 06:45 PM   #8
Mooly's Avatar
Originally Posted by mtl777 View Post
Why not the ZL which has lower impedance and higher ripple rating than YXF?.
Lol... because I tend to stick with what I can get locally from C.P.C. as they are within easy reach if I need something quick.
Also have a good range of Pana NHG and FC series and oooh Sanyo OSCONS.
Old 2nd June 2010, 07:34 PM   #9
Yeah, the ZL are pretty hard to find especially here in the U.S. Newark has it but not DigiKey or Mouser. I wonder why those big distributors do not carry any Rubycon caps?
Please help ID Wima cap mtl777 Parts 7 25th May 2010 04:51 PM
Little help with ceramic cap ID? peace brainerd Parts 1 4th December 2008 08:36 PM
Need help - Old cap can ID atmars Tubes / Valves 5 7th July 2008 04:03 PM
ID a cap?? Jacco? mpmarino Parts 10 27th September 2007 11:55 AM
Roederstein cap ID please redrabbit Parts 5 25th January 2006 07:46 PM
Page generated in 0.12041 seconds (79.13% PHP - 20.87% MySQL) with 11 queries
