Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Vintage Transistors
Vintage Transistors
Old 28th September 2012, 02:29 PM   #61
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by zakman35 View Post
I have recently found 5 x NEC 2sb248 transistors, new unused, but i cant find any datasheet about them.
Do you have any idea if they worth the trouble to build an amp with them?
Can you point me any suitable circuit?
Thanks in advance
ask there:
Toragi.com
2SB248 - Toragi.com
or there:
NEC EMEA
Old 28th September 2012, 11:49 PM   #62
GopherT is offline GopherT  United States
Parameters are listed here. Not exactly a DATASHEET but enough to get started.
2SB248 Datasheet. 2SB248 Equivalent, PDF Data Sheets - Parameters and Characteristics. Electronic Component Catalog.
Old 30th September 2012, 06:24 PM   #63
zakman35 is offline zakman35  Mozambique
Thank you both.
Do you think they worth the trouble to build and amp based on them?
Old 30th September 2012, 06:36 PM   #64
The old PNP germaniums a were used as Class A amplifiers in the late 1950s transistor AM radios in automobiles. Not because the were great or because Class A was great but, instead, because it was cheap, and a lot easier and more reliable than the tube amps they replaced (imagine how long a filament in a tube would last in an old-time car with bad roads and low-tech suspension and plenty of engine vibration.
They are not going to sound amazing, but they might make a unique sound for a low wattage guitar amp. I would at least set up a breadboard to see how it sounds - or if it even works after all these years.
Old 2nd October 2012, 11:22 AM   #65
Thanks Gopher, i would follow your advise to see how the sound.
Old 19th November 2012, 05:21 PM   #66
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Young guys may think old things had crappy sound
Not real.... we had beautifull sound in the past...now a days we have a lot of bad sound devices around.... so much or more than we had in the past.
Human ears are the same.... 50 years ago or today...live music also the same..so...old folks knows what is a good sound...maybe young folks have never listened to a live orchestra...some of them do not know what is this.
Listen a recording made with a cheap digital camera.... a Germanium amplifier playing from 1968....old thing, old capacitors (young guys goes replacing all them and fast) and with wonderfull sound.
how audio (could have) sounded on 14 may 1968 - YouTube
regards,
Carlos
I am alive and healthy folks... for Brazil only product: https://www.youtube.com/watch?v=6A_g8uPHHO4: https://www.youtube.com/watch?v=DTXl1eEgygk
Old 26th July 2015, 08:22 AM   #67
geraldfryjr is offline geraldfryjr  United States
Any have any info on the very old Honeywell power transistors Circa about 1957?
I have a friend that has about 30 or so of the H5 types.
The number he gave me is H5B5D2.
He was thinking about building an amplifier with these and I suggest a classic transformer driven Class AB/B or something may be the easiest design to do.
He was thinking about using four of them per amplifier.
Any info at all would be Great!!
Cheers !!
jer
Old 26th July 2015, 08:28 AM   #68
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
When I was an Aprentice Test Engineer in 1967at Weymouth Radio (Weyrads), I was told by the Chief Engineer that Germanium Transistors had a shelf/useful life of 25years. Silicon had no such shelf life.
What happens is the Germanium gradually gets leakier and leakier until the gain or Hfe returns to 1.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 26th July 2015, 08:48 AM   #69
Hmmmmm....Very interesting I will tell my friends this.
I asked him to check the hfe if he could and he will get back with me later on this.
I told him to expect a rather low hfe from what little data I could find if it even pertain's to this family of devices.
jer
Vintage TransistorsHide this!Advertise here!
Transistors for 80's vintage amps archangele Solid State 10 31st October 2013 12:43 AM
Vintage Transistors Captn Dave Swap Meet 1 29th May 2010 04:32 PM
vintage sansui transistors honsten Solid State 4 29th May 2010 01:59 PM
Looking For Output Transistors For Vintage Car Radio 65blkbkgt Car Audio 14 29th May 2010 01:58 PM
Vintage Transistors antiquekid3 Solid State 12 29th May 2010 01:54 PM
