| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello, I'm pretty new to this idea of modifying speaker crossovers but I don't know which caps I should use. I heard Black Gates are pretty good but they don't make the exact values that my crossovers use. I have a stock 10uF 100V cap and a 8uF 100V cap (I'd have to buy 4 for biwire), but the only Black Gate AC that comes close to this is a 10uF 50V. Would it be possible to use this cap without any problems? Should I try non-AC BG caps to make this fit?
Thanks |
#2 |
It shouldn't be a problem using that cap (I guess you mean lower voltage), as the AC Non-Polar caps for speakers are made only in 50V . The other one that comes close to 8u is 6.8u from BG. It also depends where the caps are located in a crossovers. Sometimes slightly different value doesn't affect response that much, sometimes it does.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 | |
Everytime I turn on my stereo I am amazed by what these guys can do. |
#4 |
I bought some Multicaps RTX from a forum member who replaced them with BG. Although I never tried BG in speaker's crossover.
#5 |
Thanks you guys. The AC BG caps work fine, my speakers sound fuller, more dynamic. Sorry for my long delay I just installed them today.
| Correct gate drive waveform ? | alexclaire | Power Supplies | 11 | 20th August 2008 02:17 PM |
| Black Gate observation | MikeFarad | Parts | 1 | 17th June 2008 06:12 PM |
| black gate capacitors! | lanchile07 | Chip Amps | 5 | 12th November 2007 12:01 PM |
| Black gate types C & Std etc | tubenut | Analog Line Level | 2 | 4th August 2005 09:43 PM |
| Page generated in 0.09587 seconds (65.89% PHP - 34.11% MySQL) with 10 queries |
