Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th May 2010, 06:11 AM   #1
Default Does this two circuit have the same output?
Actually i want to combine this two circuit(above part) by using only one center tap transformer. At the beginning i'm using two type of transformers but now i want to combine it to become using one type of transformer to save down one transformer. So instead of using one 24-0 and one 12-0-12 transformer i combine it together by just using one 24-0-24 center tap transformer as shown at the bottom part.
Does my circuit correct to get the final output voltage as the upper part?
thank you.
Old 27th May 2010, 04:30 PM   #2
Speedskater's Avatar
No it has a problem:
In the second drawing, the Circuit A bridge can't be connected to ground.
Kevin
pre amp output delay circuit? tomat Tubes / Valves 6 19th September 2009 03:36 PM
I/V + Output opinions needed for this circuit georgehifi Digital Source 8 3rd April 2007 03:14 PM
0db output indicator circuit xdissent Solid State 1 24th November 2003 05:25 PM
Coax output circuit (SPDIF) Vinnie R. Digital Source 1 10th June 2003 04:20 PM
6h30 dac output circuit wanted..anyone? tone Tubes / Valves 19 6th February 2003 05:07 PM
Page generated in 0.05874 seconds (70.69% PHP - 29.31% MySQL) with 11 queries
