| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hey guys,
I may be the only one, but I find caps hard to identify. I've got a bunch here labeled: MDC Z5U 1000M 1.5K V the other side is blank. The case is like a ceramic cap only thicker. I also have some tantelum caps that say: 224 ADP on one side and 270 AIJ on the other. So whats the deal, is it 220000pF or 27pF...? Its a tiny cap, so I'm guessing 27pF. Pete P.S. Yes, you can freely make fun of me... |
#2 |
can you post some pictures? for the MDC's those labels don't make much sense asociated with the case. as for the other ones they are 220 nanoF at 270 volts
#3 |
me again; the only way to be sure about the values is to measure them with a dmm (one that can measure caps in a farely wide range)
#4 |
diyAudio Moderator Emeritus
I say....
The tantalums are 22*10E4 = 0.22uF. They don't make tant's much lower in value. No idea of the voltage. How big are the others? They sound like: 1000mF = 1uF But they'd be big in size for this value. Cheers, |
#5 |
first cap is a mov (varistor) if it looks like a thick ceramic capacitor
#6 |
MDC Z5U
1000M 1.5K V Z5U is a well-known code for a very bad ceramic dielectric. M is probably a tolerance code, meaning +/- 20%, which is a good value for the initial tolerance at room temperature and low voltage for Z5U capacitors (they vary more over their temperature and voltage ranges). 1000 is then almost certainly the capacitance in pF and 1.5KV denotes a 1.5kV maximum working voltage. All in all, these are very bad 1000pF +/-20% ceramic high voltage capacitors, capable of handling 1.5kV. |
#7 |
Thanks for the replies guys. I think I've pretty much got them figured out now, but can anyone suggest a good (ie. cheap) DMM for testing capacitance?
Pete |
| Damn UPS & brokers stuff | Elkaid | The Lounge | 37 | 28th March 2006 02:59 AM |
| My DoZ for headphones won't bias... damn... | Lisandro_P | Solid State | 11 | 3rd August 2003 07:17 AM |
| Damn | Steve Eddy | Everything Else | 4 | 20th February 2003 11:25 AM |
| Page generated in 0.32665 seconds (20.22% PHP - 79.78% MySQL) with 10 queries |
