Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th May 2010, 08:55 PM   #1
aevek is offline aevek  United States
Default Component Identification
Hello all.
I'm trying to fix a set of EV SP-1502 speakers. When they were given to me I was told the drivers were blown. When I hooked them up, one speaker did nothing and the other distorted badly and output seemed very erratic. I opened them up and directly connected the speakers individually to the power amp and found the speakers sounded fine, which led me to believe something is blown in the crossover.
The two components in the second picture are the ones i'm hard up to identify. I originally thought they were capacitors, but the labeling and placement makes me think they're resistors. Can anybody clarify for me? I know the big grey block is a 20watt 50ohm resistor, the copper coil is an inductor, and the big white doohickey is an 8ohm potentiometer for high frequency attenuation.
Old 16th May 2010, 10:39 PM   #2
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
The two blue objects are 5 uF and 2.84 uF film capacitors. Should be very reliable parts, but it's possible for them to fail leaky or shorted.
Old 16th May 2010, 10:52 PM   #3
Apex Jr is offline Apex Jr  United States
To add to it....
The K on both is 10% and are made by Tecate Industries in Mexico
Steve @ Apex Jr.
Old 17th May 2010, 02:25 PM   #4
Thanks guys!
Old 17th May 2010, 08:30 PM   #5
So I think I found replacement parts for these, but I had a question.
I found 5uf 100v and 2.7uf 100v polyester film caps. I know having a higher voltage rating is ok, but will the lower capacitance of the second cap affect the crossover slope drastically?
Old 18th May 2010, 01:29 AM   #6
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
The voltage rating is the same, 100V. As for 2.7uF vs 2.84 uF, given that the originals were 10% tolerance, if the 2.7's are close to nominal then they should be well within 10% of the original 2.84. If you can get 2.7's that are 5% or better you are golden!
Old 18th May 2010, 02:28 PM   #7
Oops I spaced- I meant the 5uf is 350v. But thanks for the clarification!
Old 20th May 2010, 12:17 PM   #8
Caps like that are usually fairly reliable, so I'd check the other components too if I were you... in particular the pot to see if it is intermittent. If it is, try to find a classic sealed wirewound model with double wiper, these are practically indestructible. I can imagine these speakers were dramatically overdriven for the crossover circuit to fail like that. Looking forward to know if your replacement caps solved the problem!
- Robert
PS: I do have a bunch of those 8 ohm wirewound pots if you need to replace 'em.
Old 25th May 2010, 06:17 AM   #9
aevek, mind if I post some unidentified electrical objects on here? I have an idea, actually. Why doesn't this topic get stickied so anyone who finds things they can't identify can post them all in one thread? It'd help keep the forum cleaner and give good visibility.
Old 27th May 2010, 05:46 PM   #10
I don't mind Llamaboy. Sounds like a good idea to me.
And thanks Robert, I'll keep that in mind. However, I tested the pot and it seems fine. in fact, I pulled both caps and tested them, and they seemed fine as well. I'm kinda stumped, so i opted to just replace the whole shebang.
Only thing now is that the 5uF cap terminals aren't labeled. I really don't wanna put it in there backwards. Any ideas?
Diode Identification the intimidator Chip Amps 4 14th May 2010 09:17 AM
Component Identification Spax Parts 5 6th May 2009 04:53 AM
Need identification if possible. es44 Full Range 2 11th September 2008 08:38 AM
Identification this driver Piapia Multi-Way 2 19th February 2004 08:10 AM
Page generated in 0.09011 seconds (85.03% PHP - 14.97% MySQL) with 11 queries
