| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
The Motorola MC3340 has been discontinued. It was simple and I happily used it.
Can anyone tell me if there is a substitute that is simple to use as a Voltage controlled amplifier or attenuator please. Thank-you, Russell WIlliams |
#2 |
You may be able to use the National LM13700 which uses a different principle but can be used in voltage controlled gain mode
My blog: Consort3′s Blog |
#3 |
Simple, comparatively high noise and high THD%.
I've seen folks use a pot and a serial ADC to write a word to a digitally controlled pot, frankly if you're going to go this route you should consider something really great like the Texas Instruments PGA2310. Maxim had some easily controllable digital pots. |
#4 |
There are a number of european and japanese ICs having a similar function: the TDA1074 f.e.:
http://www.datasheetcatalog.org/data...ps/TDA1074.pdf |
#5 | |
G² |
#6 |
#7 |
Some version of the SSM20xx series,
http://www.tenmilecreek.net/images/ssm2016/ssm2016.htm or any of the VCA's from THAT corporation: http://www.thatcorp.com/THAT_IC_Sele...ide.shtml#VCAs jd
/Another new issue: Linear Audio Volume 3! Last edited by janneman; 13th May 2010 at 09:05 AM. |
#8 |
THAT Corp IC's are now carried by Mouser --
#9 |
I have a couple dozen SSM2018 in PDIP if you're interested.
| SqueezBox substitute | jkeny | Digital Source | 123 | 13th December 2009 01:05 AM |
| 2SD873 substitute ? | garnet | Parts | 1 | 27th September 2007 09:32 AM |
| Substitute for mosfet | darkm4n | Parts | 2 | 23rd April 2007 10:57 AM |
| Substitute to 2N5484 | Ryssen | Parts | 1 | 18th April 2007 12:58 AM |
| Page generated in 0.09716 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
