Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th May 2010, 06:14 AM   #1
Default Audio transformer question
If I have a step-up audio transformer with two independent primaries and two independent secondaries, can I connect the input to one primary and one secondary, and connect the output to one secondary and one primary, and thereby get a 1:1 ratio?
Any sneaky pitfalls?
Old 11th May 2010, 06:23 AM   #2
runebivrin's Avatar
Send a message via MSN to runebivrin
Why make it so complex? Just use the primaries or the secondaries. Leave the other pair open.
Do wizards use spell checkers?
Old 11th May 2010, 06:30 AM   #3
chris661's Avatar
What he said. Just make sure you insulate the ones you don't use.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 11th May 2010, 06:38 AM   #4
Oh yeah. D'oh!
Hmm... Would I get better signal level using all the coils, though?
Edit: oops -- meant SNR, not level as such. Need more coffee... No of course I wouldn't would I, I'd get more copper loss due to increased winding resistance. Primary inductance would be increased so the low-end response would be extended some, but otherwise there'd be no improvement in using more coil, would there.
Audio transformer smile44 Parts 5 11th August 2008 03:26 PM
Audio Transformer Inductance Question kelticwizard Everything Else 1 9th April 2007 05:28 AM
Audio Transformer design BudP Introductions 4 11th March 2007 09:41 PM
using audio isolation transformer pjpoes Parts 5 10th May 2005 12:56 PM
Winding an audio transformer mark_titano Tubes / Valves 3 24th February 2005 10:38 AM
Page generated in 0.08909 seconds (71.99% PHP - 28.01% MySQL) with 10 queries
