will any/all of the following 3 circuits work? will my circuit (attached) also work? do i need to add anything, can i remove anything? do i need feedback? one of the 10k resistors in the right hand potential divider will be a verial resitor to set temp. also, the values are not correct, i will have to play around. thank you for any help in advance.
http://www.uoguelph.ca/~antoon/circ/heatsens.html
http://www.rason.org/Projects/fancont/fancont.htm
http://www.overclockers.com.au/techstuff/a_thermalfans/
thanks again
thanks again
i was thinking that there are three ways to do this:
a potential divider connected to a transistor's base
the circuits above
a thermister used in a 555 timer circuit, used as a PWM pulse contolling motor speed
which would be best? i have made a working prototype of my circuit above.
the circuits above
I haven't found easier
My dad put this together a few years back, I hope it help.
Matt....your a cheapo..LOL....with the parts you have you can build a temp. unit...there are a alot of design examples out there using an op amp as a comparator....if you really want it for free go to Maxim`s site and look at the Dallas temp controllers I`m utilising one right now with a PIC
DIRT®
DIRT®
- Design & Build
- Parts
- temp cantrolled fan circuit
