| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I plan on powering something off of 4 AA rechargeable batteries. The problem is if I discharge the batteries any lower than .8v per cell it will damage them. I need to make a cutoff circuit that will turn off the batteries once they reach 3.2 volts. Anybody have any idea how?
#2 |
Weird idea.
Bistable relay (latching) to allow 4 AA battery power to pass. Create a comparator circuit using LP339 (not LM339) for low power consumption (60uA standby?) and trigger the relay to unlatch when the comparator hits threshold voltage. Normal idea. Mosfet transistor on = 4 AA battery power to pass. Mosfet transistor off when voltage drops below threshold = power cutoff. |
#3 | |
Cheers, Mark |
#4 |
There are special IC's called voltage detectors to do things like that. Look for ILC5062 from Fairchild, XC61C series from Torex, some available from Microchip (TC53, TC54), Texas Instruments (TPS3836) and others. All these chips consume on average about 1 microamp, some even less than that (TI chip - 220nA) and available for a wide range of voltages in about 0.1V increments. These are not terribly expensive and usually very precise (1 or 2 % tolerance).
Cheers Al |
| voltage balancer circuit | zilog | Power Supplies | 0 | 17th April 2008 08:52 PM |
| Low Voltage Cutoff circuit needed | MikeHunt79 | Power Supplies | 10 | 15th January 2008 11:49 PM |
| What is the correct plate voltage in this circuit? | Sunsun22 | Tubes / Valves | 2 | 10th November 2006 01:43 AM |
| Heater voltage circuit change......why please | frank2395 | Tubes / Valves | 5 | 25th May 2005 11:33 AM |
| Instant voltage and current circuit? | CWChang | Solid State | 3 | 19th January 2005 02:42 PM |
