Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help me find a better sub for 1N4007
Old 9th May 2010, 02:52 AM   #21
On Hiatus
SY's Avatar
Originally Posted by mtl777 View Post
Thanks, I'll do it then. BTW, is it also commonly done even with good diodes like UF4007?
Haven't seen it done, but that doesn't mean it isn't done. The cap-across-rectifiers was something I did when building RF gear many years ago- before there were UF4007s. Got that trick from the Radio Amateurs' Handbook.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th May 2010, 01:53 AM   #22
mtl777 is offline mtl777  United States
Oh, I forgot about one important detail -- the voltage rating of the bypass cap. The bypass cap I have available is 0.01 uF 100V polyester. Is it gonna be fine for bypassing the UF4007 which has VRRM (max repetitive peak reverse voltage) of 1000V, VRMS (max RMS voltage) of 700V, and VDC (max DC blocking voltage) of 1000V? If not, what should the voltage rating of the bypass cap be?
Old 10th May 2010, 01:58 AM   #23
On Hiatus
SY's Avatar
You want a high voltage cap there, with good HF characteristics. 1000V ceramic should do fine.
Old 10th May 2010, 02:26 AM   #24
Thank you so much! It's good that I asked and didn't put them in yet.
Any particular brand/series you would recommend or just about any 1000V ceramic will do?
Old 10th May 2010, 02:31 AM   #25
flyinglemur is offline flyinglemur  Canada
A good high-voltage Schottky, fast response. Ample capacitance after, and a second-order EMI filter...then the power supply!
Help me find a better sub for 1N4007Hide this!Advertise here!
How to find out which is which???? jamesjung21 Tubes / Valves 2 28th November 2004 07:05 PM
Can anybody tell me where can I find this? red Multi-Way 5 25th June 2003 08:13 AM
replacement diodes for 1N4007 jarthel Solid State 9 28th April 2003 01:26 AM
Rectifier vs. 1N4007 or 1N5406 sangram Solid State 10 17th February 2003 06:58 AM
Copyright ©1999-2017 diyAudio
