| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I adjusted the idle current on my Yamaha A1020, and noticed some residue at the base of two pairs of caps (see pictures). Is this just glue as I have read something about this, or should the caps be replaced? I do not notice any changes in the sound.
The first pair of caps are Rubicon Black Gate F 25V 1000uF: ![]() The second pair are Nichicon 25V 1000uF: ![]() This is a newbie question, so sorry if the answer is obvious..... Also, sorry for the picture quality - if required I can try to get better pictures..... If I need to replace the caps, I would appreciate suggestions of what caps to by, and where to by them... The Rubicons are part of the power supply circuit and the Nichicons are part of the Eq amp. |
#2 |
The caps in the second photo are definitely glued. Leaking electrolyte isn't very thick, it won't pile up against a cap like that.
The caps in the first photo might be leaking, but I can't really tell. That's not a great photo. Is the brown stuff corroding the surrounding components? If the amp is more than 15 years old and you still want to get the best out of it, you should be looking at replacing the caps regardless of whether they are leaking or not. |
#3 | |
And yeah...a re-cap would be a good idea anyway. Very simple fix. Welcome to DIYAudio
Jim J. |
#4 |
In both cases, that looks like glue to me. PArts that stick up from the board are more likely to vibrate back and forth and crack free of their solder. Manufacturers often glue larger parts down to prevent this.
| Yamaha Nippon-chemi 10,000 uf 71V caps (india) | suds | Group Buys | 0 | 16th April 2010 08:44 AM |
| White residue sign of Leaking Caps? | clm811 | Parts | 4 | 15th October 2009 08:54 PM |
| leaking current | jb_val | Solid State | 15 | 15th December 2005 10:00 PM |
| Luxkit A1020 need help!!! | huytienluu | Tubes / Valves | 4 | 28th October 2004 09:26 AM |
| Are my caps leaking or glued on? | Zuma | Parts | 7 | 24th September 2003 01:43 AM |
| Page generated in 0.08536 seconds (72.43% PHP - 27.57% MySQL) with 10 queries |
