Filling up the free M&K enclosures - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th May 2010, 04:21 PM   #31
badman is offline badman  United States
Custom Title
badman's Avatar
Make sure you seal your edges guys.
The MDF/Chipboard on these isn't the most stable material. Run a bead of woodglue along all exposed edges and rub it in with your finger. Also, make sure to coat the inside of any screw holes to stabilize the material. For this you can use superglue and chase with a screw (immediately remove) if you plan to be unscrewing/rescrewing several times, if not, woodglue works fine.
Also, if you're using the sanding drum expansion method, you may find you have a less than true hole. Specifically the "bottom" of the recess may retain a lip. Fortunately this nice soft MDF can be easily scraped away with the appropriate flat-head screwdriver. Just scrape it around a few times and you can make sure the bottom of the recess is as open as the top.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 3rd July 2012, 07:33 AM   #32
Anybody think these might be a good match for the MK boxes?
The sealed box design with a 3.65 cubic feet volume (Qtc of .707) has an f3 of 44 Hz. (incredible stereo or musical instrument sound)
Originally designed for an audiophile high-end speaker system.
Re = 6.3 ohms
Le = 1.49mH
Qm =9.70
Qe=0.44
Qt = 0.42
Xmax 4.8mm
Voice Coil Diameter 2.50 inches
Fs = 26.6 Hz
Vas = 6.68 cubic Ft
Sd = 519.45 square centimeters
Magnet weight 56 oz
Sensitivity 91dB 1W/1m
Old 9th April 2013, 01:17 AM   #33
expert in tautology
bear's Avatar
You guys sugck!!
All the really neat stuff seems to always be getting given away or sold in CALIFORNIA!! Always!
Gosh those are really nice looking cabinets!!
You guys must be grinning ear to ear!!
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 9th April 2013, 02:15 AM   #34
Custom Title
badman's Avatar
Originally Posted by bear View Post
You guys sugck!!
_-_-
I have used them for several projects, most recently, the addition of a rearfiring 12"+horn to the "big" rig. Click the image to open in full size.
That's a JBL 2206h with my own flavor supertweeter per Building A Budget (Super?) Tweeter Reaching the stratosphere! Article By Jeff Poth
Crossover is a damped 2nd order electrical on the supertweeter, with a notch, and the midwoof wide open (the 2206h is very well behaved on the top end). Effectively it's about 3rd order at 2500.
Old 9th April 2013, 06:24 AM   #35
They are pretty, but so far pretty empty in my garage. Free boxes ended up with me buying a LOT of various drivers and related items, but haven't had time coincide with space to mess with them. I have the nagging feeling that I may have bought the wrong impedance drivers for my duo woofer subs, but soon I hope, soon.
Old 17th February 2015, 03:39 AM   #36
Default M&K sub
Sorry to revive an old thread but does anyone have any of the 250 watt plate amps they want to sell?
thanks
bill
grifftek
at
live dot com
or text me at 562
five three three
4772
Free enclosures Harderror Full Range 2 3rd May 2016 05:29 PM
Help on the filling please? fouchagalaga Subwoofers 11 5th March 2010 05:19 PM
FREE FREE - Panasonic A310 DVD Player - FREE FREE Kane Williams Swap Meet 6 27th September 2008 02:35 PM
Subwoofer cabinet filling & net volume increase dis Subwoofers 0 4th July 2004 03:51 PM
Filling enclosures avatar307 Multi-Way 5 22nd December 2003 05:50 PM
Copyright 1999-2017 diyAudio
