Filling up the free M&K enclosures - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd May 2010, 03:04 PM   #21
badman is offline badman  United States
Custom Title
badman's Avatar
Originally Posted by mikeford View Post
I'm taking my son to Howies Gameshack either today or one of the Friday's soon, so I think I may stop by Deepsurplus and get a couple of the $42 woofers they sell for the dual boxes. I bought the last small M&K plate amp that ApexJr had, and its supposed to fit the dual box, so I might actually have sound before much longer.
If you didn't already make the trip....
I believe they're out of the $42 woofers. Infinity Kappa Perfect car subs seem like a good match, as do the creative sound trio 12. I'm going to be doing a few with the trio.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 3rd May 2010, 08:13 PM   #22
I bought a pair of the 8 ohm $42 woofer, but didn't ask about larger quantity. Talking to Dave (head Hamster of Hamster audio I think, guy who built the speakers DeepSurplus sold as complete units anyway) and it "may" turn out I grabbed my push pull cabinets from the "wrong" pallet, and may have a smaller internal volume and different sized amp plate spot. Hopefully sometime later this week I will get a chance to check.
Old 5th May 2010, 03:33 PM   #23
Custom Title
badman's Avatar
Son of a gun.... it turns out that the half-dozen of the dual cabs I picked up were ALL the smaller size. Very disappointing as I could very much use the additional cabinet volume!!
Anyone who got some of the bigger ones and would like some smaller ones, or some of the other cabs (I have quite a few of the cherry vinyl-veneer boxes, some of the odd-angle "tubes", some of the gloss mini-enclosures, and a few other odds 'n ends) please let me know. I also have a fair number of grilles, for the larger peg-style sub cabs (they don't fit the cherry), so if anyone has these and needs grilles, let me know.
Old 5th May 2010, 05:32 PM   #24
boywonder's Avatar
If the grills that don't fit the cherry cabs fit the maple cabs, I'll need a few of those.
Old 5th May 2010, 06:10 PM   #25
drjlo is offline drjlo  United States
Glad I found this thread.
I picked up 4 of the bigger single-driver sub boxes and secured the drivers from Deepsurplus (not bad for the $42 price at all), but these drivers only fit on 2 of the 4 boxes
I need to figure out how to widen the outer radius a little bit.. That drum sand looks like a good idea. Where did you get it and for how much?
Also 3 of the 4 boxes actually have plate amp holes that fit the M+K 250 watt plate amp (which I bought from Apex Jr), but the problem is they have pre-drilled holes with metal inserts on the other side, so you can't use the screws that come with the plate amps. Using what seems like the right-size screw, some of the holes/inserts lock in good but others just spin. They may be stripped from prior use (the boxes definitely look used).
I *was* able to assemble one subwoofer with the Deepsurplus driver and M+K plate amp, and it does sound very good, nice and tight. HOWEVER, I can hear metallic rining and pinging from the plate amp as volume goes up, which I can lessen by putting my hand on the heatsink/plate. I'm thinking about just sealing the plate amp hole with some MDF and use the plate amp externally. Will need to make plate amp enclosures
Looks like I'm looking at some significant woodworking. Any suggestions on good woodworking shops around Zip 91784 (Upland, CA)?
Old 5th May 2010, 06:21 PM   #26
boywonder's Avatar
Can you post a few pics of the boxes that fit the 250W apexJr amp?
Old 5th May 2010, 07:15 PM   #27
Custom Title
badman's Avatar
I got the drum sander at OSH but HD or Lowes should have them too. Just a drill attachment. Maybe 10 bucks?
Easier solution is to find the right sized cigar box, hack it to fit, and use that to cover the backside of the plate amp. you only need a hole for the speaker wire. You lose a tiny bit of enclosure volume but not too bad. If you'd like to take a trip to Tustin I'd be happy to help you with the job.
Old 11th May 2010, 04:18 AM   #28
This is the first I assembled. For the next two, I'm likely going to house the M+K amp externally and seal the back of subs with something (mdf?).
Old 11th May 2010, 09:41 PM   #29
How is the sound?
Old 12th May 2010, 12:56 AM   #30
How is the sound?
QUITE nice, actually. I've always meant to use it for 2-channel music, so I have not/will not really stress it for loud movie bass spectaculars. In large home theater rooms meant for showing off bass, I imagine one should get one or two of them 15-18" ported monsters.
For music, first and foremost, I look for subs that blends well with mains and provide defined bass extension without going "boom" "boom" "boom" separated from the main music. Thankfully, this sealed sub disappears really well while doing its job.
I do prefer how the line-level input sounds over speaker-level, but I have found that to be the case with most subs I've tried.
The M+K plate amp has no back plate, so not isolated, and I do hear metallic pings and ringing if I'm at the rear of the sub, listening. Thus my plan for externally housing the plate amps for my other boxes..
Free enclosures Harderror Full Range 2 3rd May 2016 05:29 PM
Help on the filling please? fouchagalaga Subwoofers 11 5th March 2010 05:19 PM
FREE FREE - Panasonic A310 DVD Player - FREE FREE Kane Williams Swap Meet 6 27th September 2008 02:35 PM
Subwoofer cabinet filling & net volume increase dis Subwoofers 0 4th July 2004 03:51 PM
Filling enclosures avatar307 Multi-Way 5 22nd December 2003 05:50 PM
Copyright 1999-2017 diyAudio
