Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Filling up the free M&K enclosures
Old 18th April 2010, 05:44 PM   #11
badman is offline badman  United States
badman's Avatar
Originally Posted by boywonder View Post
How big is the cutout on the cherry cabs? The cutout on the maple cabinets is 12 1/4".
Badman: I'm totally set up for making a router template to enlarge the holes if you need one. I've got several routers, collar set, two circle guides, bearing bits, table saw, etc, etc. Fixture alignment could be the headlock sockets on the cabinets.
Thinking somewhat outside of the box for a minute........One could bolt a number of these together back to back and front to front to make a large volume cabinet. Of course, the drivers would be either pointing at the floor, the ceiling, or both if the resulting cabinet is positioned vertically. This could be done without molesting the cabinets by popping out the T-nuts in alternating cabinets and screwing the cabinets together with thin weather stripping between them.
I snagged 15 of the maple cabs for some experimentation.
Here are a few pics of the maple sub cabinets for those who haven't seen them:
Knowing what I know now, I wish I'd gone for maple. I like the cherry but the cutouts are undersized, at 12" OD 11" Through hole (also true of the dual sub cab I measured). The bolting cabs together is a good idea, I've been kicking it around too. One could fairly easily also jigsaw some cutouts and stack them vertically if 4 ft wasn't enough.
I may take you up on the jig assembly. Sounds like you have a better idea of how to go about it than I do. I was going to do an 11" circle to align it, and a set of slots to router through. There were still some difficulties in my mind though. I'll try the sanding drum route first though.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 18th April 2010, 07:31 PM   #12
boywonder is offline boywonder  United States
boywonder's Avatar
Do you have any grills that fit the cabinet without grill cloth on them? If so, we're halfway there jig-wise.
Are your cherry cabs the vinyl-wrapped ones or the cherry veneer ones? Do they have a hard front edge or the beveled front edge?
Old 18th April 2010, 09:46 PM   #13
boywonder's Avatar
I don't think that you're limited to 4 ft3 when bolting back-to-back. You could probably do back-to-back then front to front etc for any length stack that you want, all without molesting the factory cabinets. Odd numbers of cabinets will have a back and a front showing and even numbers of cabinets bolted together will have fronts exposed.
Old 19th April 2010, 04:08 AM   #14
mikeford is offline mikeford  United States
2x12" is equivalent to an 18" for displacement.... just how loud do we want to go here?
I have a ServoDrive Contrabass kit (waiting on doing the box), loud and low is the hard trick.
Not sure how much it might help, but if finding an amp plate to fit the dual boxes doesn't work out, an external amp could be used and the amp space could be opened to the rest of the chamber.
Old 19th April 2010, 04:34 PM   #15
badman's Avatar
Certainly true, I'm thinking more of the form factor and potential line effects. On the other hand.... if you lined all of yours together you could have a 15hz (or thereabouts) quarterwave pipe!
Appreciate the offer of help with an expansion template. The Grilles don't fit the cherry cabs so can't use that as a template base. I'm going to give the drum sander a quick go 'round, I'm usually pretty good freehand.
Best!
Jeff
Old 22nd April 2010, 05:46 AM   #16
badman's Avatar
The holes were easily expanded with a drum sander. The JBL 122a fit in with a few passes with the drum sander. They're looking great.
Old 22nd April 2010, 02:52 PM   #17
boywonder's Avatar
Nice!..... pics?
Old 22nd April 2010, 09:25 PM   #18
badman's Avatar
Attached are 4 pics. They show the drum sander, the gasketing, the velcro baffle fixing, and the marking of the inner lip (you can see a sharpie in the box, and the blackened MDF edge).
Don't forget to wear a mask and clean the dust out of cab (leafblower works well). Keep some rubbing alcohol and paper towel to clean any marker slips. I cut the pegs off with a veneer saw. The #8 machine screws are not very large but work well with some drivers. With modern drivers, you may wish to apply more fastener points and (T nut/ hurricane nut /wood insert/superglue in a screw-tapped hole). The vintage JBLs I'm using only have 4 holes, and fit a #8 screw well.
Old 26th April 2010, 05:36 AM   #19
badman's Avatar
Default Pushmepullyu
Reworked a pair of the push pull cabs this weekend. One magnet side fires into the manifold, one cone side. Limited testing so far but they seem very very VERY impressive. Signal processing functions are via Reckhorn B-1, the amp is a cheap old Yamaha I have, and the drivers are modded JBL 122A.
The 122A is about 40 years old, I refoamed them, and after testing and finding that they'd lost their alnico magnetic charge (higher Qes), I coated to cone to add mass and optimize them for OBs. They work well in these too.
Old 30th April 2010, 06:05 PM   #20
I'm taking my son to Howies Gameshack either today or one of the Friday's soon, so I think I may stop by Deepsurplus and get a couple of the $42 woofers they sell for the dual boxes. I bought the last small M&K plate amp that ApexJr had, and its supposed to fit the dual box, so I might actually have sound before much longer.
Filling up the free M&K enclosuresHide this!Advertise here!
Free enclosures Harderror Full Range 2 3rd May 2016 06:29 PM
Help on the filling please? fouchagalaga Subwoofers 11 5th March 2010 06:19 PM
FREE FREE - Panasonic A310 DVD Player - FREE FREE Kane Williams Swap Meet 6 27th September 2008 03:35 PM
Subwoofer cabinet filling & net volume increase dis Subwoofers 0 4th July 2004 04:51 PM
Filling enclosures avatar307 Multi-Way 5 22nd December 2003 06:50 PM
Copyright ©1999-2017 diyAudio
