Better replacement for Wima MKS output caps? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th April 2010, 07:43 AM   #11
mjf is offline mjf  Austria
q:If you see a voltage marking like "250" on a Wima film cap, is that voltage AC or DC?
marking........250 - ......means dc volt
greets
Old 11th April 2010, 07:10 PM   #12
mtl777 is offline mtl777  United States
Thanks, guys!
I decided to buy three different brands/series of the caps in question:
Epcos MKP
Vishay BC MMKP 383
Evox Rifa PHE840M
I think these are the top three (in that order) of the choices available at DigiKey. I will give each of them a listen and choose what sounds best in my DAC.
Question: Do caps like these need a break-in period before they can sound their best? If so, how long do they need to break in? Due to the limited time I have for this project, I really wish they don't need any break-in so that I can just try one brand and immediately replace it with another if I don't like how it sounds.
Old 12th April 2010, 08:43 PM   #13
Film & foil capacitors are usually much better than such metalized film caps.
The PP film & tin foil caps from Relcap are worth to try.
Here's looking at you, kid.
Old 27th March 2013, 04:22 PM   #14
AmCan is offline AmCan  Canada
Originally Posted by mtl777 View Post
Thanks, guys!
Epcos MKP
Vishay BC MMKP 383
Evox Rifa PHE840M
I am looking now to replace some strange values in my HK 17 EQ like .056uf and .0027uf. I am going to have to go with one of these 3 brands as well unless I can find the Multicaps in these values. I am curious now to know how each cap sounded to you?
Old 27th March 2013, 04:37 PM   #15
Thanks, guys!
Epcos MKP
Vishay BC MMKP 383
Evox Rifa PHE840M
Old 28th March 2013, 11:23 AM   #16
oncle tom gave you your answer PETP K73-16, bright at the top end to begin with but superb right from the get-go.
I removed an awful 0.1uF/160V Wima MKP 10 cap, the first cap in the pre-amp section of my hybrid amp and removing this crap and replacing it with a K73-16, 1uF/250V opened up my whole system.
These K73-16 caps are rated at either 5% or 10% but actually measure much better - the 0.1uF typically are either spot-on or within 2%.
Because they are so cheap, you can buy 10 of them and match them exactly, very important for coupling caps if you want a truly balanced response from your speakers.
You will be sick at wasting your money on those other caps.
Black Stuart
Old 28th March 2013, 01:03 PM   #17
The size might be also a deciding factor. PETP capacitors of same capacity and voltage are much bigger than polystyrene types. Polypropylenes are also bigger. Film & foil of the same type is bigger that metallized foil. It seems the general rule applies here: "size matters".
Old 28th March 2013, 01:35 PM   #18
Belief me I would love to use the PETP or the RTE for that matter, but can you find me a .056uf or .0027uf? Were are you buying the PETP from? I have the K75-10s w/FT3 bypass caps for my crossovers. However, in this instance size is going to matter as the space is designed for a 12mm long cap. I could squeeze a PETP in there if I knew where to get the non-standard values.
So my question remains, in the absence of availability, which is the better polypropylene cap to use? or polyester? Which poison would you choose?
Old 28th March 2013, 01:39 PM   #19
Perhaps you can use silver mica in that capacitance values. They are better than any plastic foil type.
Old 28th March 2013, 01:47 PM   #20
Good suggestion. I know the values are available but i will have to find them all in one place to keep the shipping costs down. If I do any comparison test I will report back on what I found to work well. In an EQ application I really want the caps to be as neutral as possible.
Wima FKP / MKS vs. Evox Rifa PFR / MMK jonclancy Parts 11 11th August 2013 07:09 AM
Wima MKP vs MKS supernet Parts 80 5th April 2010 09:01 PM
WIMA MKS or Ampohm for output coupling? nad Parts 6 20th March 2010 10:39 PM
Sale: Wima Mks 4 - Mkp 10 max29 Swap Meet 1 11th August 2007 10:56 AM
FS BB OPA660AP, WIMA caps, ROE Caps and other Andypairo Swap Meet 10 13th August 2005 02:46 AM
Copyright 1999-2017 diyAudio
