Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th April 2010, 06:29 AM   #1
mbl is offline mbl  Angola
Default diy shunyata research (Helix Geometry) cable?
Anyone know how to braid a cable like shunyata research (Helix Geometry) cable?
Old 1st August 2010, 07:46 PM   #2
krajnc is offline krajnc  Serbia
krajnc's Avatar
find some copper wire from old burned transformer and take a practice
here is the guide
Interlaced, counter-rotating, multiple-helix cable
Old 4th August 2010, 04:06 PM   #3
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
well that guide makes it perfectly clear good luck with that. I think it would be just as easy to invent your own cable as to follow this guide. I think it is clear enough, but in practice this will be a total PITA and not at all clear if you have made a mistake I would think.
Old 4th August 2010, 08:11 PM   #4
krajnc's Avatar
yes it could be PITA, luckily me, as a young I made a macrame hammock for camping and this one is easy , well, and some pigtails (not on me)
Old 5th August 2010, 05:02 PM   #5
qusp's Avatar
ah yes I make lots of very good braided cables for work also (up to 8 wire), but the counter rotating interlinked spirals with multiple ground planes seem to me to be far more difficult than any hammock. for with a hammock all strands are visible at any one time and it lays in a single plane pretty much, where this is far more complex than that. doable for sure, but it was designed with machines in mind and the main thing as I said is not being able to clearly see internal links from the exterior once you have moved on. the description and diagram makes it look harder than it probably is in reality, its a patent afterall
all I can say is it'd better do as it claims, the time spent braiding a 10' cable of this would be worth 1000 dollars in time to me there comes a point where DIY is nolonger the cheaper option when that is taken into account. though I dont know the pricetag on the cable in question ;D I actually quite enjoy braiding; but I would prefer to lay back sipping cocktails on a hammock I just knitted; followed by a nice nap; than make one of these
Old 5th August 2010, 07:56 PM   #6
krajnc's Avatar
agree,
price? look here: MUSICDIRECT - SHUNYATA - AURORA INTERCONNECT (Pr)
reviews? here: SoundStage! - The Audio Authority - www.SoundStage.com - Shunyata Research Aeros Aurora-IC Interconnects and Aurora-SP Speaker Cables
very good and very expensive
I am curious to find out how easy is: me = or
I'll try to braid one and post some hq pictures here
I don't have that "alpha cryo enhanced" blah blah cable
but i have some good wire (silver coated and without) with teflon insulation
and I'll give it a try
Old 6th August 2010, 05:46 AM   #7
Use pure copper, silver coated r not good sounding.
Old 5th October 2010, 11:36 PM   #8
How to braid or diy Dual counter-rotating HELIX Geometry?
Old 6th October 2010, 01:28 PM   #9
krajnc's Avatar
you must look at the picture and try to figure out by yourself
there is no other method
that is what I'm doing now
its not easy at all
wish you good luck
Old 12th October 2010, 10:54 AM   #10
I have seen the document about this patent us 6242689 but there is only the schema for eight wire and not for 16 wires that is the last in shunyata research.
In every case I don't understand for these eight wires the wires for the hot pole and the wires for the ground.
Anyone knows because I think to make this geometry and if there is someone who think to make this cable please write to me to give his impression and his solution.
my email...
sandro.perusini@gmail.com
Why do YOU DIY? Answer for my college research paper. gripracer Solid State 40 6th November 2009 06:53 AM
Preamp - DIY vs Audio Research (or similar) fourrings Tubes / Valves 20 21st December 2006 04:15 PM
Help with design/geometry for DIY table...designers wanted :) Glowbug Analogue Source 11 13th December 2006 09:58 AM
Shunyata Power Cords.... Voltaic The Lounge 10 3rd July 2006 12:44 AM
electrical cable for DIY speaker cable? leadbelly Multi-Way 7 13th January 2004 10:43 AM
Page generated in 0.09135 seconds (86.44% PHP - 13.56% MySQL) with 11 queries
