| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#41 |
The first problem with SPDIF is the horrible RCA connector, this realy limits the design possibilities.
Back soon, on this course so I've goto do some work! |
#43 |
I made some interconnections, not tested yet,
it is ok to use hollow tube, if you have power connector with two wires, drain wires are not part of helical interlacing elements, but will help to physically ties conductors
OPPO 83, Stabi, PS Audio III Line & RIAA, Audio Innovation First, Energy 22 Pro, Kimber KCAG |
#44 |
could u make some video for braid shunyata ? i'm desperate to find out how to braid this cable.....
#45 |
Yes, I'll make video. But I need some free time and right mood.
here is stratos ic clone, little shorter (70cm) waiting for wbt rca connectors and spare time to test Have pair of kimber KCAG, cant wait to compare
#46 |
testing soon
#47 |
and balanced
#48 |
practicing 16 wires
#49 |
Why power cables and speaker cables use dual helix geometry(two drain wires/cores) but signal cables use single helix geometry?
| Why do YOU DIY? Answer for my college research paper. | gripracer | Solid State | 40 | 6th November 2009 06:53 AM |
| Preamp - DIY vs Audio Research (or similar) | fourrings | Tubes / Valves | 20 | 21st December 2006 04:15 PM |
| Help with design/geometry for DIY table...designers wanted :) | Glowbug | Analogue Source | 11 | 13th December 2006 09:58 AM |
| Shunyata Power Cords.... | Voltaic | The Lounge | 10 | 3rd July 2006 12:44 AM |
| electrical cable for DIY speaker cable? | leadbelly | Multi-Way | 7 | 13th January 2004 10:43 AM |
