| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
you must look and figure it out in your head
there is no other way here is my first attempt with lot of colors - bad idea (pic1) try with only two colors hardest part is beginning |
#12 |
Just what is this cable for?
AC power, speaker, unbalanced interconnect or balanced interconnect.
Kevin |
#13 |
For connecting the speaker to the amp.
#14 |
Geezz...no way do I have the patience to do a cable like that one.
I admire that some people do
#15 |
#16 |
power cable
dual counter-rotating helix geometry 616 wires awg 15 x 2 just waiting for furutech connectors king cobra kk - f.jpg |
#17 |
Wich awg did you use for white and for blue/black? How many cables did you use for blue or black? A pic of starting the cable will be nice.
#18 |
white conductor is not a part of helix geometry
"Some embodiments of the present invention also comprise drain wires which are not interlacing elements and which run longitudinally within or adjacent to the helices. Shielding may also be employed to help reduce noise from external sources." it is commonly used for grounding, and should be larger in diameter (easier to braid) there is 6+6 awg13 conductors and it is only for heavy loads (amplifiers, welding machines etc )I hope this helps
#19 |
I bet my granny could knit this in half hour.
#20 |
lucky you
free cables
OPPO 83, Stabi, PS Audio III Line & RIAA, Audio Innovation First, Energy 22 Pro, Kimber KCAG |
| Why do YOU DIY? Answer for my college research paper. | gripracer | Solid State | 40 | 6th November 2009 06:53 AM |
| Preamp - DIY vs Audio Research (or similar) | fourrings | Tubes / Valves | 20 | 21st December 2006 04:15 PM |
| Help with design/geometry for DIY table...designers wanted :) | Glowbug | Analogue Source | 11 | 13th December 2006 09:58 AM |
| Shunyata Power Cords.... | Voltaic | The Lounge | 10 | 3rd July 2006 12:44 AM |
| electrical cable for DIY speaker cable? | leadbelly | Multi-Way | 7 | 13th January 2004 10:43 AM |
