| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi I am trying to source some coax with the following specs...
wondering if it rings any bells for anyone? 75 ohm Silver plate over copper, single strand 0.6mm core, Teflon dielectric insulating material between core and silver plated copper braid. White Teflon outer covering Any Ideas? |
#2 |
oh and a capacitance of 23pF per metre.
#3 |
actually, I realise those capaticance figures are completely unreasonable,
so, lets just say lowest available. |
#4 |
1:Application,
Applicable to video field, communication system and signal controlling system; video monitor circuitry, broadcast signal control, public TV antenna, closed-circuit TV monitor system; wireless telecommunication, transmission system and unilateral control or internal wire of high-frequency machine. 2:Product Description Characteristic impedance: 75Ω Twisted single or multiple strands of bare copper wires as conductor Solid polyvinyl insulated Aluminum shielded outside Aluminum shielded outside Bare soft copper wire or tinned copper wire braid shield PVC jacket Keeping working temperature under 70℃ for long-range operation |
#5 | |
G² |
#6 |
RG 179 / U coax is fairly close to what you specify, and is readily avalible and cheap.
#7 |
hey lads sorry I am a bit late in replying, Thanks for the great suggestions, much appreciated! going to look now...
| Hi-eff two-way using Eminence Coax or not? | Godzilla | Multi-Way | 5 | 8th August 2009 06:37 AM |
| Steel-core Coax ?? | redrabbit | Parts | 10 | 12th December 2008 03:45 PM |
| Best 5.25 coax drivers | Zero One | Car Audio | 2 | 9th September 2006 12:47 AM |
| SDI and mini coax??? | Htguy | Digital Source | 0 | 13th April 2005 04:31 AM |
| Optical/Coax to analog? | soundNERD | Digital Source | 2 | 29th September 2003 03:01 AM |
| Page generated in 0.10324 seconds (77.25% PHP - 22.75% MySQL) with 11 queries |
