Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd April 2010, 07:13 PM   #1
Default Relation between voltage and noise in capacitor
Hi guys!
I'm gettin'in Hi-Fi world so I'm building a simple phono preamp for my cheap turntables (MM cartridge).
I'm using the Thorsten schematic.
Since my cousin have an electronic repair shop I used hi voltage capacitor like ERO 1813 630V and wima FKP1 1000V, and a strange kind of capacitor in transparent plastic...
With a LCR meter I match them to the last digit! The same for resistor... opamp are OP275 since the original is difficult to find for me....
Now the question is: hi voltage capacitor is noisy than low voltage?
Old 2nd April 2010, 08:17 PM   #2
A pure reactance doesn't generate any thermal noise thus capacitors, inductors and transformers are inherently very quiet. Any internal loss that's represented as a resistor (the capacitors DF or the inductors Q) does, but it's usually negligible. Capacitors are also low impedance at higher frequencies, so HF noise will never be an issue. Noise pickup is another matter, and that's what you usually have to worry about. The capacitor voltage shouldn't matter, only the physical location and probably construction to some degree. Caps are also microphonic, some much more than others. IMO, you want polystyrene or polypropylene for RIAA equalization caps in a preamp for sonic reasons.
Conrad
I used to be an audiophool like you but then I took an arrow to the knee.
Old 2nd April 2010, 08:23 PM   #3
nigelwright7557's Avatar
You can get problems with higher value electrolytics capacitors at high frequencies.
Some people put a small capacitor across them to soak up high frequency noise.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd April 2010, 09:53 AM   #4
Many thanks to all!
Yes the electrolitic is bypassed by 100nF wima mkt capacitor!
I never heard microfonic in capacitor! Is there any document? maybe with measure?
Old 3rd April 2010, 02:59 PM   #5
I've never seen much published on microphonics. Try a search. One could put an accelerometer on a cap and vibrate it, recording the output, but that's too much work! You can wire a cap to the input of a preamp and tap it with a pencil, listening for the output. Try it with a high dielectric constant ceramic cap and I think you'll be surprised at how much signal is generated. Cables have the same problem. Put a few feet of cable on a preamp input and tap that- it's a very common issue with microphone cables. There are special low noise cables with conductive layers that reduce the problem, but they're not common in audio; they're more common in low noise measuring equipment.
Conrad
Old 4th April 2010, 05:31 PM   #6
OK Conrad! I'll try to search, and I'll try this interesting experiment :-)
For the cable I know they are microphonic, I build several guitar amp and fx and also experiment with cables!
over voltage for capacitor space2000 Solid State 4 27th May 2008 12:58 PM
Relation between voltage gain and dB amplification klitgt Solid State 9 18th August 2005 12:17 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
relation between ampere, voltage and distortion or linearity oliverniekamp Pass Labs 4 17th June 2002 08:38 PM
capacitor voltage Chad Solid State 9 27th September 2001 06:57 AM
Page generated in 0.10206 seconds (71.22% PHP - 28.78% MySQL) with 11 queries
