| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a C2003 L182 Transistor and am looking for a good replacement for it? Thanks!
#2 |
#3 |
The BC639 or MPSA06 will do I would think, not quite as high gain on average but voltage is suitable.
#4 |
#5 |
I have to agree the MPSA06 is different but the BC639 is the same pinout looking at the datasheets on line.
The MPSA06 would need its pins bending, a route I have travelled many a time fixing old kit with obsolete / unobtainable parts. |
#6 |
I thought the Japanese transistors were different from almost every one else. There are some exceptions I know, but I didn't check on that one.
The exact part is still available at the link I posted for $0.20 in singles. |
#7 |
Thanks Steve I ordered 4 of them!....
#8 |
Could someone tell me where i need to put my two leads with my dmm to test for idle current on my driver board? I have no schematics for this or anything Hard to find!, so i would just be testing what it is already and adjusting both for the same.Its for a Project/one 1500
thanks! |
#9 |
also the pot in the middle of the board is the bias one..
#10 |
Measure across the .47ohm 5watt resistors. BTW- I noticed they don't all match. .5ohm and .47ohm... It would be a good idea to have them all the same (even though I know they're close). If you have the opposite channel to measure as a reference, you can set it to match. It'll be millivolts, maybe 10-20mV or so... Just a guess. Set it, and see how warm it gets just sitting idle, with no signal.
| Looking for replacement transistor | kockaboy | Parts | 4 | 15th October 2008 04:51 PM |
| transistor replacement | xcicc | Solid State | 0 | 16th August 2008 10:05 AM |
| Transistor Replacement | portlandlay | Solid State | 26 | 14th December 2005 07:46 PM |
| Transistor replacement | Mlaen | Solid State | 3 | 18th February 2005 11:00 AM |
| Page generated in 0.10522 seconds (75.49% PHP - 24.51% MySQL) with 11 queries |
