Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th March 2010, 02:22 AM   #1
Default How to pair the RCA to 5 Pin DIN?
Dear All,
I'm noob here and I've search through this forum of how to diy the 2 RCA to 5 Pin Din for my old philips reel to reel player.
As far as I know, the 5, 4 are for the L,R signal. And 2 is for grounding, so, can I ground the sleeve of my 2 RCA cable together into pin 2? Will it cause any distortion or hum to the amplifier?
Old 15th March 2010, 08:44 PM   #2
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
Standard pinout for 5 pin din on a tape recorder is
Pin 3 Left output
Pin 5 Right output
pin 2 earth
Pin 4 right input
pin 1 left input
to go from the tape to a preamp use pins 3,5 and 2 where 3 and 5 goto the inner pin of the RCA and pin 2 to both shells.
to record from a tape out on a preamp connect the RCA's to 2(earth) 4 and 1
(for the tape in socket of a pre-amp the wiring is reversed to 3 and 5 inputs and 1 and 4 outputs)
Hopefully I got it the right way round, I still use DIN on my old amp
8 pin din for kenwood WHEELS Car Audio 7 21st February 2012 05:12 PM
DIY Interconnect: 5 pin DIN to RCA Coober Everything Else 7 11th July 2008 03:04 PM
5 pin din power supply? Trojan Instruments and Amps 1 26th September 2007 12:09 PM
5 pin din to rca how to. saltyreefguy Parts 1 10th June 2006 10:12 PM
7-pin DIN connector pinout? Mr Evil Everything Else 0 25th November 2004 03:21 PM
Page generated in 0.07543 seconds (66.48% PHP - 33.52% MySQL) with 10 queries
