Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th March 2010, 04:52 PM   #1
toufu is offline toufu  United States
Default Center Tapped Transformer?
Is it possible to make a center tapped transformer from a transformer with 2 secondaries? If I have 2x24, can I tie the 2 wires in the middle to become the center tap and I have a 24-0-24 transformer?
Old 11th March 2010, 04:58 PM   #2
Yes, but if using it to drive a convential full bridge rectifier, make sure
that the two single leads are out of phase with respect to each other.
Old 11th March 2010, 05:13 PM   #3
Thanks for the reply but can you elaborate on that? How do I make sure they are out of phase?
Old 11th March 2010, 05:22 PM   #4
bobodioulasso's Avatar
If the windings are tied out of phase, you will measure 0 volts instead of 48 v across the two extremes. If so, reverse one winding . Though, generally colours tell you what is what. The center tap, in this case joins two different colours.
Old 11th March 2010, 05:23 PM   #5
Do you have a scope?
Old 11th March 2010, 05:27 PM   #6
No, I don't have a scope. I usually get my transformers from Antek, I suppose I can ask them, but do you know if their transformers are tied out of phase or not?
Old 11th March 2010, 06:07 PM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Tie two of the leads together and measure the AC voltage at the other two. If you measure mV, then you have them connected + - . - + Reverse one of the secodaries and you should see the voltage of both secondaries in series, + - . + - The connection point between them is the CT.
Peronsally, I prefer two seperate secondaries. This way I can make two seperate full bridge rectifier and filter circuits, then tie them in series at the star GND.
All the trouble I've ever been in started out as fun......
Old 11th March 2010, 08:08 PM   #8
Thanks guys, I just call antek and they told me that just tie the two middle wires to make it a center tapped transformer.
Old 19th April 2011, 05:21 PM   #9
Hello, sorry for reopening an old topic, but I have a similar question.
I have bought a Myrra 44310 transformer and it has a separate 2x15V outputs, however I need a center tap, can I just connect the two middle taps to get a center tapped transformer?
http://www.farnell.com/datasheets/41189.pdf
Old 19th April 2011, 11:49 PM   #10
Minion is offline Minion  Canada
Yes , make sure the windings are in phaze .....
Two positive rails from a center-tapped transformer? KT Tubes / Valves 6 14th November 2009 12:25 AM
Transformer wiring question, series, parallel and center tapped swin1 Power Supplies 12 7th November 2008 07:58 PM
Center tapped transformer help Buzzy Parts 2 8th August 2008 09:35 AM
1-bridge PSU for center-tapped transformer: What's the disadvantage? Spasticteapot Chip Amps 4 23rd March 2006 10:02 PM
Giant 1:1 Center tapped transformer fo sale!! PhaseShift Swap Meet 3 4th July 2002 07:59 PM
Page generated in 0.10168 seconds (78.31% PHP - 21.69% MySQL) with 10 queries
