Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
ESP P68, 500v ceramic caps?
Old 10th June 2003, 07:36 PM   #1
Kram is offline Kram  United Kingdom
Default ESP P68, 500v ceramic caps?
Hello,
I am compiling a parts list on RS for ESPs 300w sub amp, in the BOM on ESPs site it says that 2 500v 100pF ceramic caps are needed (C3 and C6). I dont seem to be able to find any on RS. Does anyone know if they are available?
On ESPs site it also says that Polystyrene caps could be used insted of ceramic ones, so if RS dosent stock 500V 100pF ceramic caps what Voltage rating should the Polystyrene substitutes be?
This sub is to be used in a HT set up so it will be plugged into the sub out of my surround receiver, these are just line level outputs usually and therefore I will need some way of controlling volume, correct?
What methods of volume control have other people used and would recommend, I am looking for something simple(ish) and cheap.
Thank you
Kram
Old 10th June 2003, 09:00 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
C3, C6 could get around 100 V across it but hardly at higher frequencies (then you have needed a heavy duty type). Use 100 V at least but can be risky. I recommend >200 V.
Rod says that this capacitor should be of a good quality, doesn't hurt but at bass frequencies those caps don't "exist", don't do anything. They do their job at higher frequencies (100 kHz- 1 MHz)
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
ESP P68, 500v ceramic caps?Hide this!Advertise here!
X7R vs NP0/C0G Ceramic Caps speakerguy79 Parts 4 6th March 2007 11:52 PM
200V ceramic caps AndrewT Parts 2 22nd April 2005 02:11 PM
Teflon 0.056uf/500V caps JBasham Swap Meet 0 6th August 2003 07:30 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Why different kinds of ceramic caps? sam9 Solid State 4 24th September 2002 03:48 PM
Copyright ©1999-2017 diyAudio
