| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm going to need a 20 amp IEC plug for the end of a power cord to power my new amp, but I don't feel like paying $100 for this on some audiophile parts supplier sites. Ideally I would like a pure copper one, but I can't locate a source.
Anyone have a link or a supplier you can direct me to? Thanks, Bob |
#2 |
is this the C19/20 connector? if so then its only a few £
16 Amp IEC Plug Mouser has it as :- 161-PX0599 S 20A/250VAC 3 wire C19 socket DigiKey as 708-1349-ND Last edited by Spiny; 1st March 2010 at 09:07 PM. |
#3 |
You sure your home electrical system is able to deliver 20A? At least in europe, at 16A protection kicks in and shuts off to protect the wiring - and your home.
Have fun, Hannes |
#4 |
The amp has a 20 amp receptical on it, so I need a 20 amp plug for the end of the cord. According to the manufacturer a 15 amp circuit is sufficient to drive it. It is a high powered solid state amp and the max power is only limited by the current it can draw from the wall, so a 20 amp circuit would be ideal if I really want all of that extra power, but it's not absolutely necessary.
That 16A plug looks similar to what I need, but it is not it. Thanks anyway. |
#5 |
Remember that with AC power systems, 16A or 20A fuse or circuit breaker is designed to carry it's rated current continuously. In the US continuous means 3 hours. The only way that a fuse or breaker limits current is by tripping or fusing. (with the small exception that higher current rated circuit parts will have less voltage drop).
There is a larger safety rating in power components and most parts and wires can operate at almost twice their rating continuously without failing.
Kevin |
| RCA OUT & IEC from QUAD 99CD PLAYER ? | rubydac | Digital Source | 3 | 30th December 2009 06:56 AM |
| Source for All-In-One IEC Socket? | DrDeville | Parts | 5 | 23rd February 2007 10:45 PM |
| Power Amp Toroids 20-0-20 VAC 500 VA | daedalus | Swap Meet | 17 | 24th May 2006 07:30 PM |
| Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? | vinyvamos | Tubes / Valves | 1 | 28th January 2006 04:07 PM |
| Hubbell H320B IEC 20 amp chassis connectors | sivalleydiyer | Swap Meet | 0 | 1st March 2004 10:31 PM |
| Page generated in 0.09996 seconds (75.92% PHP - 24.08% MySQL) with 10 queries |
