Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th February 2010, 12:05 AM   #1
Audio Junkie
Zero Cool's Avatar
Default Comparing Transistor Specs for swap
I am working on an amp where a previous repair shop has changed the stock transistors from 2SD716/2SB688 to 2SA1492/2SC3856
Comparing the datasheet's I see that the voltage and current rating of the 1492/3856 devices is higher but the rest of the specs look similar. I'm curious to know if these devices are close enough to be an acceptable swap as i have more of the 1492/3856 devices on hand but not the 716/688 devices. Im wondering if there is a reason i should change these devices back.my only hesitation is the added time to order the parts.
http://www.datasheetcatalog.org/data...NGS/2SB688.pdf
http://www.classiccmp.org/rtellason/...ta/2sa1492.pdf
Zc
Need transistor with BD139 specs but higher wattage? Dr. Popo Parts 10 22nd October 2009 06:34 PM
Comparing 3 topologies hahfran Solid State 19 24th November 2008 08:33 PM
Transistor specs. Help!...do you know those units? destroyer X Solid State 9 11th September 2005 11:25 AM
Comparing Bose(o) Chip Amps 5 29th July 2005 09:19 PM
2SB1353 Transistor specs? Chris Daly Solid State 8 27th September 2004 02:47 AM
Page generated in 0.06656 seconds (68.40% PHP - 31.60% MySQL) with 10 queries
