| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I was contemplating cobbling together a 2-way car audio component system, but most of the cheaply available crossover networks I see on ebay are intended for 8 ohm speakers. Of course, most car audio speakers are 4 ohms.
As I am a novice at this stuff, can someone explain the effects/consequences of using a 2-way, 8 ohm crossover with 4 ohm speakers? I did search, but I was unable to find a complete answer to my question. Thanks in advance for any info! |
#2 |
speakers don't stay at there rated impedance, due to resonances & inductance they vary all over the place. Crossovers need to be designed for the exact drivers in use, if they aren't & even if you have a crossover of 4 ohm rating to match your drivers the chances are that they won't crossover smoothly. Offhand i can't remember which way things would go. Using 4 ohm drivers will likely shift the crossover frequency, so you'll either end up with a rather large peak with both drivers contributing to this, or a rather large dip in the response where both have rolled off Or maybe a combination of the two..For use in a car though & if you don't give a monkeys i suppose you could live with it ![]() I couldn't
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#3 |
Maybe get an active crossover ??
| 4-ohm Speakers on 6-ohm Amp? (newbie question) | diesel_88 | Multi-Way | 23 | 25th October 2007 08:54 AM |
| Connecting 8 ohm speakers to a 4 ohm amp | mulliganmaster | Multi-Way | 7 | 1st July 2007 09:33 PM |
| Can you use a 8 ohm crossover with 4 ohm speaker? | Bull | Subwoofers | 1 | 19th May 2005 08:37 PM |
| Matching my 8 ohm amp to 16 ohm speakers. | DocJDG | Solid State | 3 | 5th December 2001 01:54 PM |
| 4 Ohm or 8 Ohm speakers impedance for Aleph 5? | Piter | Pass Labs | 2 | 1st November 2001 07:15 PM |
| Page generated in 0.08537 seconds (71.69% PHP - 28.31% MySQL) with 10 queries |
