Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd February 2010, 04:37 PM   #1
Bill_P is offline Bill_P  United States
Default Stepped Attenuator Modification
I bought some cheap DACT knock-off attenuators from an Ebay seller in Hong Kong for $10 each. They are stereo series attenuators containing twenty resistors per channel. My amplifier uses two separate volume controls for the two channels so only one section of each attenuator was used.
I would have preferred to use a ladder attenuator rather than series and the two poles in the switch allowed conversion to a ladder type as shown in the picture.
The original resistors were removed with two soldering irons and discarded. New resistors were "tombstone mounted" and connected with a fine strand of silver plated OFC wire. The schematic shows how everything is connected. I think there is a bit more clarity to the sound with fewer resistors in the signal path.
stepped attenuator onno Pass Labs 20 25th September 2007 09:04 PM
stepped attenuator ivegotmono Tubes / Valves 4 7th January 2006 02:49 PM
Stepped attenuator Bas Horneman Tubes / Valves 24 16th June 2004 07:18 AM
Stepped Attenuator officeboy Parts 3 6th May 2004 03:32 PM
Page generated in 0.07384 seconds (68.19% PHP - 31.81% MySQL) with 11 queries
