| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Mr. Nelson Pass start this tread in september 2009:
Best electrolytic capacitors Here are not SMT capacitors - only such outlines with screw or solder terminals Now I start the same thread here, but concerning only the not leaded outline for the surface mounted technology. By repair service I observe often swelled tops by SMT caps like that one from the attached photos. In the moment by the main PCB of Pioneer's DVD player DV-717 (DV717) I discover several 4V SMT caps that have get swelled tops. The problem by the most SMD/SMT electrolytic caps is, that I cannot find a logo to get conclusions about the manufacturer brand. An additional problem is to identify the correct polarity. The black marking is sometimes for the negative polarity and sometimes for the positive. I want to know brand names for top quality caps in the outline like that from the photos. Who can give me therefore some advices? Last edited by tiefbassuebertr; 15th February 2010 at 05:24 PM. |
#2 |
Nichicon UQ
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) www.overture.org.ua |
#3 | |
I typically stock the highest voltage for a given value and SIZE (A,B,C,D,E,F) so as to reduce inventory. It's fine to use a 35V cap to repace a 16V cap though obviously the reverse is not true. Nichicon has good caps though they tend to cost a bit more and don't function any better so I only buy Nichicons if there is no Panasonic available. As for which brand was originally used, who cares? It wasn't any good or you wouldn't be replacing it. Except for really expensive gear, they buy like I do but they are primarily into price and will it work long enough to get past the warranty period. G² |
#4 |
thank you for your statement. I think you mean this caps:
http://industrial.panasonic.com/www-...BA0000CE88.pdf The long life version of Arcotronics SMD could be also a good choice: www.arcotronics.com/download/aluminium.php?id=1 www.arcotronics.com/download/aluminium.php?id=2 Last edited by tiefbassuebertr; 15th February 2010 at 07:15 PM. |
#5 | |
G² |
#6 |
I like the best part ...
less focus there .............
#7 |
Who knows the brand name of this smt electrolytic capacitors uses by ASUS main boards for personal computer (see also attachement)?
ASUS Motherboard - 78 Times Longer Lifespan than Expected! |
#8 |
AVX maybe ?
#9 |
OS-CON Kondensatoren - endrich Bauelemente Vertriebs GmbH (various PDF for download, website in German, PDF in English)
#10 |
The red caps with the small 'F' are Fujitsu, Asus uses them on all their motherboards in 'middle' and 'premium' ranges.
| SMT capacitors for audio | Markus2006 | Parts | 4 | 1st October 2008 01:37 PM |
| Ceramic caps: SMT as good as radial? | speakerguy79 | Solid State | 13 | 20th November 2006 02:04 PM |
| Surface mount capacitors | chris ma | Parts | 45 | 30th November 2004 12:05 PM |
| Kemet A700 ALuminum Organic SMT caps? | BrianL | Parts | 3 | 4th August 2004 08:16 AM |
| Surface mount devices. | JoeBob | Parts | 2 | 7th February 2002 03:14 PM |
| Page generated in 0.12202 seconds (81.56% PHP - 18.44% MySQL) with 11 queries |
