| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
I'm looking for female RCA gold plated copper that would be good match for the Eichmann plugs.
#2 | |
diyAudio Moderator Emeritus
Vampire has a complete line of gold plated RCA jacks. They have both gold over nickel on copper or direct gold on copper. http://www.vampirewire.com/ Rodd Yamashita |
#3 |
Now that I give it a little more thought, the Cardas RCA jacks with the rhodium over silver on copper would do just as well. Both the rhodium and gold are highly inert metals and will not readily oxidize. You can find them here.
http://www.diycable.com/catalog/main/about.htm Rodd Yamashita |
#4 |
Account Disabled
Thanks!
#5 | |
se |
#6 |
Account Disabled
What do you recommend?
#7 | |
![]() And I'm not saying the Vampires are necessarily bad. Just pointing out that the "direct gold" which is supposedly to avoid the ferromagnetic nickel plate that's typically used doesn't quite eliminate ferromagnetic materials from the mix. But if ferromagnetic materials are any concern (and that depends on the individual of course), then the Cardas connectors Rod already recommended would work fine in that regard. Neither silver nor rhodium are ferromagnetic. se |
| rca jacks | reddish75 | Digital Source | 2 | 24th September 2006 05:53 PM |
| Copper heatsink tweak - Thermaltake Copper Heatsinks | Ruach | Digital Source | 16 | 23rd September 2006 10:59 PM |
| Seeking gold, ganged RCA panel jacks: | GrahamnDodder | Chip Amps | 6 | 17th January 2004 08:10 AM |
| Gold plated jacks to... | johnferrier | Everything Else | 1 | 21st December 2003 05:09 AM |
| Can't find RCA jacks | Roepke | Everything Else | 4 | 4th April 2001 01:30 AM |
