Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2010, 01:48 PM   #1
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Default Wire Wound Resistor or Inductor?
Hello everyone, I am rebuilding some Coral 3-Way speakers. There is one component I am curious about. Not sure if it is a resistor or inductor.
I measured it and it has a DCR or 9.5 ohms. I am thinking it is a resistor since a inductor would have a DCR of 9.5 ohms. The component is hollow though.
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Last edited by 69stingray; 29th January 2010 at 01:48 PM. Reason: forgot attachment
Old 29th January 2010, 02:54 PM   #2
zigzagflux's Avatar
Resistor. I think the 5L was an old Ohmite model.
Old 29th January 2010, 08:18 PM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
It even says 10 ohm right there on it... Resistor!!
The reason it's hollow is that it's wound on a ceramic tube to allow for better heat dissipation. This is/was a pretty common practice for wire-wound resistors.
~Tom
Old 29th January 2010, 11:45 PM   #4
magnatar's Avatar
resistor , ceramic air cooled
Old 29th January 2010, 11:52 PM   #5
Thanks everyone, I thought so. It just looks so much like an inductor and it is on the midrange, so it was possible. I wouldn't think an inductor would have a DCR of 10-ohms.
Audio DIY Page
Old 30th January 2010, 01:24 AM   #6
zigzagflux's Avatar
Lots of inductors could have DCR's of 10 ohms. They range from less than one ohm to greater than 1k ohm. Point is, this one isn't an inductor based on the construction, regardless of the labeled or measureable parameters.
Typically, an inductor is labeled in henries and possibly amperes; a resistance value is much less common, and would only be included in addition to henries.
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
Why not wire wound potentiometers for volume? tem00 Chip Amps 18 16th January 2009 01:48 PM
Wire Wound Pontentiometers - resistors neazoi Tubes / Valves 1 12th January 2009 11:08 AM
Inductor wound with THHN ? seventenths Parts 4 24th April 2008 10:58 PM
Wire Wound Resistor Failure? jjai Solid State 6 3rd March 2005 07:32 PM
Page generated in 0.09716 seconds (74.66% PHP - 25.34% MySQL) with 11 queries
