| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi, I have just recieved my two nice big transformers today, but at the moment I know very little about them other than the fact that they are 40 - 0 - 40 rated with two 115 primarys (will be wired in series for 230 opperation). The external dimensions for them are 200 X 80 mm, they weigh about 10kg (or more) each and the secondary windings consist of three strands of 1.5mm diameter solid copper wire for each connection. SO, I was wondering if anyone would like to take a guess at what teh VA rating for these things might be. Or, if there are any people out thre who have large (1000VA+) transformers already which i could compare these up against. I have included a pic below, which also shows a computer disk for the size reference if that will help.
sorry, but I realy can't spell today.
#2 |
Post an accurate weight so others can weigh theirs of known rating for comparison.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#3 |
Hi, I have checked the weight, and the transformer comes in at a hefty 13.6kg (30lbs). I guess this goes some way to explaining why I decided to build two monoblocks with these once I had picked them up, instead of one large dual mono chassis.
The biggest one I have found so far to campare it with, is a 1000VA model sold by RS in the UK whihc 'only' weighs 6.5kg, so I am very interested to try and get other peoples feedback on their own transformers. |
#4 |
Actualy, forget that last coment, I have just been having a look arround (I should be revising now, oops) and I have found a web site with aproximate weights and sizes for custom transformars and their ratings. From what their table shows, tha transformars come out somwhere in the range on 2200VA - 2700VA depending on mains frequency. SO if this is the case and some other people out there can confirm this value would be about correct for these, then I would be very happy indeed.
The page I found is here: http://www.toroid.com/custom_transfo...ransformer.htm |
#5 |
More.
I just found the picture below on the avel lindburg website, in their custom design section, and I have to say that this looks very similar to the one I have (the top one of the three), with a similar type of wrap and epoxy coating. Also, the ones I have a marked with a stamp which states "AL 8", so I think that this could very well be the scource of my transformers. I also forgot to mention before that the transformer itself has the following hand written markings on: 40/6508/3 13/94 Now, I am only guessing, but the bottom line looks like a production date (week 13, 1994), and the top line may give a better idea to it's rating, as the secondaries are 40V, and there are some additional lines which I haven't mesured yet that may corespond to the other values on there. So, as an extra question, has anyone out there ever seen what they know to be a custom transformer from avel Lindburg, and can you confirm any of the markings on it? |
| Unknown Transformer | 6f6 | Tubes / Valves | 4 | 5th April 2007 06:14 PM |
| How to characterise unknown transformer | pixpop | Parts | 1 | 31st January 2005 08:40 AM |
| How 2 determin Unknown Xfrmr VA Rating? | Zero Cool | Solid State | 14 | 24th September 2004 11:44 AM |
| Transformer VA Rating vs. Current Rating | JhonDoe | Chip Amps | 45 | 5th June 2004 01:11 AM |
| unknown transformer capabilities | Jared | Solid State | 7 | 19th September 2002 02:41 AM |
