diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   SMD component ID (http://www.diyaudio.com/forums/parts/159750-smd-component-id.html)
Perry Babin 23rd January 2010 11:21 AM
SMD component ID
1 Attachment(s)
Can anyone ID this part. The dimensions of the body are ~3mm by ~1.55mm. It's likely a dual transistor (possibly with bias resistors).
Thanks in advance.
bichi 23rd January 2010 05:28 PM
Possibly Fairchild NC7SZ00 2-IN NAND Gate?
- see package marking codes (does not indicate "B," however)
Product Folder - NC7SZ00 - TinyLogic UHS 2-Input NAND Gate, Fairchild Semiconductor - Global Leader in Power Optimization
Might be helpful to know what type of equipment it's installed in...
Perry Babin 23rd January 2010 07:32 PM
I think you're probably correct. This is in a class D amplifier. Pins 1 and 2 are tied together and driven by an opto-coupler. Pin 3 is on 'ground'. Pin 4 drives the input of a TC4420. Pin 5 is connected to a 5v power supply.
Can you tell me how you found it? I looked through every SMD codebook I could find and searched the manufacturers sites but came up blank. Even searching the Fairchild site for 7z00 or 7zoo doesn't return anything.
bichi 24th January 2010 08:05 AM
Have been designing discrete preamps/LFP filters with SOT-XX stuff, past few years...
- just got lucky this time, I guess.
- but I hear ya, 'tis a nightmare "decoding" SOT device ID's back to manufacturers lately.
Sounds like the right part from your description...
Copyright 1999-2017 diyAudio
