Source for audio-grade resistors & caps in the US? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st June 2003, 12:30 AM   #1
NH7RO is offline NH7RO  United States
Default Source for audio-grade resistors & caps in the US?
Am in the process of replacing some burned-out resistors in my Perreaux 1150B amp and some electrolytic caps in another. Specifically, two 4.7 ohm 5% (2 watt--I'm only guessing on the wattage and type) and two 12 ohm 5% resistors in the first amp and about a dozen 10 uf 100v electrolytics in the second.
Between a slow dial-up connection and learning that some parts only are sold in 500 pc. lots on some sites I'm going nuts trying to find sources.
So does anyone here know of a good reliable company online in the US that might stock such items and sell small quantities?
Anyone know where I can get HITANO EXR caps outside of Australia?
Are the resistors I mentioned above likely in the 1-3 watt range and what type did Perraux use in the early 1980's--metal film, or? These resistors are 4-banded, round and are 1/8 to 1/4" dia. x .5 inch long.... Help, please, anyone with some ideas?
Many thanks from
Jeff
Rebuilding a DAC Audio grade or Computer grade caps? gto127 Digital Source 0 28th January 2009 08:17 PM
Need Source for Audio grade 15000uf caps 5cm X 8 CM spade type for Nakamichi gto127 Parts 0 23rd January 2009 02:13 AM
Anyone Tried Nover Audio Grade Caps? Thomo Parts 22 28th October 2008 01:43 PM
Source for audio grade transformers? natzev_i Parts 2 12th October 2006 03:00 PM
Audio Grade Caps Selection Myth vs Reality ransom peek Parts 17 12th January 2005 05:43 PM
Copyright 1999-2017 diyAudio
