| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
| View Poll Results: Witch Cap do you prefere after the rectifier for low-power usage (max 25V)? | |||
| Panasonic FM |
26 | 28.57% |
| Panasonic FC |
18 | 19.78% |
| Rubycon ZL |
3 | 3.30% |
| Rubycon ZLH |
1 | 1.10% |
| Nichicon FG |
12 | 13.19% |
| Black Gate Std. |
7 | 7.69% |
| Other |
24 | 26.37% |
| Voters: 91. You may not vote on this poll | |||
Hi to all,
witch Electrolytic Cap after the rectifier do you prefer for low-power usage (max. 25V) ? Feel free to vote and post your thoughts. Best regards, Oliver
Reference TDA1541A DAC project PCBīs / Tube-I-zator V2.0 PCB / SSHV-Shunt PCB /
Pedja Rogicīs Discrete Diamond Non-Feedback I/V Stage - Stock status in my Blog |
#2 |
I've seen a lot of those "witch" Fuhjiyus causing power supply failures. I prefer to replace those with Sanyo OS-CONs.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
Of these, I believe the Panasonic FC has the lowest ESR.
Cheers! |
#4 |
just another
I was tossing up between Panasonic FM and the Nichicon FG, neither of which I have used (have used the Panasonic FC's)
Geek the FM's have a lower ESR than the FC's according to the datasheet 40-70% Less! I just checked the max value at 25V and it is only 2700 uF The FC's go up to 5600 uF at 25V and the nichicon FG's 3300 and the rubycon ZL's 2700uF so depending on what values you need the choice may need to be made based on what values you can get! in each series... Tony. |
#5 | |
donīt think much about the max. capacitance at 25V. If i would like to have more, i could insert an additional cap. Therefore i limit the question only the voltage. Best regards, Oliver
#6 |
#7 |
I've been very happy with the panny FM series. If I can't get that I use FC.
Take the Speaker Voltage Test! |
#8 |
Elna Silmic II
#9 |
I think a "witch cap" flies on a broom.
#10 |
Nichicon KZ. Mouser stocks many values now.
1N4733 |
| Electrolytic Cap Search | Peter Menting | Tubes / Valves | 3 | 5th May 2006 02:40 AM |
| can I use an electrolytic cap as coupling? | Nordic | Chip Amps | 2 | 20th September 2005 09:12 PM |
| Electrolytic Cap Testing | Giaime | Parts | 12 | 31st May 2005 09:42 PM |
| Looking For Electrolytic Cap: Power Supply | Neutron Bob | Parts | 1 | 23rd July 2002 12:19 AM |
| Page generated in 0.10693 seconds (80.88% PHP - 19.12% MySQL) with 11 queries |
