Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Right-angle PC mount noval sockets - source?
Old 15th January 2010, 12:55 PM   #1
joelap is offline joelap
joelap's Avatar
Default Right-angle PC mount noval sockets - source?
Hi all, lurked here for a while, registered to download a eagle library of tube sockets... thanks for that! I have been on the hunt for right-angle noval PCB souckets... I cant seem to find a source anywhere, but I KNOW I remember seeing them somewhere. I am putting together a bass guitar preamp in a 1U rack, and rather than place the tubes off-board, this would have me quite a bit of wiring. Does anyone know a source for these? I seem to remember seeing them in a gutshot of an Alembic F2B. Also, anyone have an eagle footprint? I didn't see a right angle one in the library I downloaded.
Thanks for the help,
Joe
Old 15th January 2010, 02:34 PM   #2
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
An easy/quick alternative is to make a small secondary PCB to hold the Socket...
Ciao T
Old 15th January 2010, 02:44 PM   #3
joelap's Avatar
Ciao T
That was my initial plan, but I'm not convinced thats the best option. I'm having the pcb etched and the company only allows one "design" for paneling. To have a second pcb etched I'd have to drop another hundred dollars or so and have a bunch of these 2-tube pcb's lying around. That, and I'm trying to minimize the length of my high impedence traces... I'm relatively inexperienced when it comes to pcb layout so I'm just trying to follow the most safeest of rules I can dig up.
Old 17th January 2010, 07:25 AM   #4
Sure, it may not be the best option, but it MAY be the best option available to you... Here an example how it can be done:
Universal Stereo Tube Output Stage (Complete with Power Transformer)
Ciao T
Old 17th January 2010, 08:12 AM   #5
poynton is online now poynton  United Kingdom
poynton's Avatar
Apex jr had them a short while ago.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 17th January 2010, 08:15 AM   #6
poynton's Avatar
still got them too.....
Old 17th January 2010, 05:45 PM   #7
joelap's Avatar
Thanks for the replies. Ponton, I will look into getting a few of those to take some measurements for making an eagle footprint. Thanks.
Old 20th January 2010, 02:34 AM   #8
Enzo is offline Enzo  United States
And Joe, whenever you do need a second board, don;t make it a completely separate board. Do what the commercial amp makers do, just make the socket board on the edge of the main board or even in the center, with perferations around it and it becomes a snap-off part.
For examples look at how Peavey made the one large board into several on like the 5150 or the Rockmaster preamp, or how fender made one board snap into three for the Hot Rod DeVille.
One advantage of making the sockets flat is that pushing the tube into the socket causes no shear stress on the socket mounting.
Old 20th January 2010, 02:38 AM   #9
joelap's Avatar
sounds like I have some learning to do in Eagle Understood about the sheer stress. I'm an recent engineering school grad, those terms are music to my ears.
I think I'm going to strip down this effort and do it on terminal strips instead for the bass preamp at least, and do non-board mounted tubes... it'll allow me to build it with the parts I have on hand with minimal sacrifice in sound quality since its only an instrument preamp, not a hifi thing. Plus it'll allow me to put more time / money towards a phono preamp.
Thanks for the heads up... lots of info on these forums.
Old 20th January 2010, 02:45 AM   #10
Good luck.
This is a great forum, joe, and another one oriented towards guitar amps is
Music Electronics Forum I suggest you visit there as well.
Right-angle PC mount noval sockets - source?Hide this!Advertise here!
Source for so8 IC sockets? PhopsonNY Parts 10 30th June 2011 09:33 PM
Are there any loctal PC sockets? Joku Tubes / Valves 2 18th May 2009 01:55 AM
Surface mount DIP Sockets? ROBSCIX Parts 6 18th June 2007 03:23 PM
Engineering Drawings PCB Mount Tube Sockets gingertube Tubes / Valves 8 2nd April 2006 01:29 AM
Orange phono sockets (PCB-mount) jimbo69 Parts 0 9th February 2004 02:17 PM
