Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th January 2010, 02:05 AM   #1
at77 is offline at77  Canada
Default Polar electro with bypass cap to replace nonpolar as coupling cap?
hey all,
just doing a mod on a recording interface - i love the sound of the kz caps for coupling. i have a stereo signal path that currently uses 4 x 22µf bi-polar caps (that i replaced with nichicon ES... were jamicon).
anyway, i have some nichicon KZ 10µf caps on hand. I really dig the sound of them on the mic preamp that i modded. I want now to try them on my main output paths. Only thing stopping me is that currently the nonpolar caps are stock.
Can I simply do this?...
drop in the KZ caps with positive lead toward the opamp, negative toward the output. then throw a 0.1µf poly bypass cap on the leads to accommodate the bi-polar-ness?
I had read somewhere that i should measure the DC voltage between each set of leads on the nonpolar caps to find any positive value and use that to orient my polar caps. seems odd to me, but what do i know. the voltage that i did measure was very, very low (fractions of millivolts). should there be signal going for such measurements if so? is it necessary?
thanks for any input.
cheers,
AT
at77
Tripath Coupling Bypass Cap Test Bed Query Davet Class D 4 9th January 2008 02:12 AM
ADCOM 18000uF electro cap PinkPink Parts 0 21st April 2006 04:31 PM
no polar feedback cap? jeapel Pass Labs 3 4th December 2005 12:28 PM
bi-polar vs. regular Electrolyte cap tomchaoda Parts 3 22nd April 2004 06:14 AM
.22uf cap in place of .25uf coupling cap, OK? bbaker6212 Tubes / Valves 5 15th July 2002 09:08 PM
Page generated in 0.06132 seconds (67.52% PHP - 32.48% MySQL) with 10 queries
