Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th January 2010, 07:05 AM   #1
Geek's Avatar
Default Coffee Maker Thermal Switches - Where to Get?
Hi Folks,
My wife and I have this fancy little coffee maker that eats thermal switches. It's our 2nd one in three years and I've replaced the switch on both until my scavenged supply runs out. @ $150 a pop, I don't feel like averaging ONE a year with switches lasting only 4 months on average (ever try to deal with an Oster warranty depot? Don't buy one! )
Any ideas where I can get these little bi-metal switches in less than 5,000 lot?
Cheers!
Old 10th January 2010, 05:39 PM   #2
Steve Dunlap's Avatar
Is this what you are looking for?
Digi-Key
Old 10th January 2010, 07:58 PM   #3
neutron7's Avatar
How about these
Digi-Key - 317-1443-ND (Manufacturer - R2009015A119)
just go to digikey.ca and search Temperature Regulators they have all different temperature ones.
by the way did you ever use those knobs?
Old 10th January 2010, 11:42 PM   #4
Geek's Avatar
OMG
I spent two hours on Digikey, enetring search terms and even downright browsing and I never found them.
(Steve, your link is shot)
Thanks guys!
** edit **
They don't have the one I need though... one like Neutron7 shows in his link, but 145C.
Old 11th January 2010, 12:28 AM   #5
star882 is offline star882  United States
star882's Avatar
Once you get the replacement switch, add a triac and resistor so the switch does not have to switch the full current.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 11th January 2010, 04:47 AM   #6
Try here: Automatic Appliance Parts -- Home
Old 11th January 2010, 05:05 AM   #7
Geek's Avatar
Thanks... but whatever idgit wrote their website, it doesn't work in Firefox
Cheers!
Old 11th January 2010, 02:34 PM   #8
now that you mention it, I remember that I had to fire up IE. On the other hand, they had the parts for the refrigerator, microwave, dryer, and maybe one or two other appliances that I have repaired over the years.
Old 12th January 2010, 01:54 AM   #9
dangus is offline dangus  Canada
Cities of a reasonable size usually have some shop that sells replacement bits for domestic appliances. Check the yellow pages.
Sometimes those switches aren't meant for temperature regulation, just protection. Is there a real temperature controller that has failed?
Old 12th January 2010, 04:51 AM   #10
Geek's Avatar
Thanks again guys.
Actually, there is a couple of ancient shops in the yellow pages that just might have them.
Typical coffee maker fashion, it's a single (as opposed to the older dual - one on the hotplate, one on the element) switch on the element rated 293F (145C) and has a thermistor on the opposite side. The bimetal click-switch works to make the coffee (it's shot, so nothing gets cooked) and the thermistor is used to regulate the hotplate once it's done making the coffee.
If I unplug the click-switch, the hotplate will be on "keepwarm" between 65C and 85C, no problem, but the water doesn't boil to make coffee.
I had *one* switch of the right temprature, but it wouldn't fit, nor could I safely fudge it in. The switches that do fit, are all "keepwarm" click-switches, rated no more than 80C :-\
Cheers!
Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches) tiefbassuebertr Parts 12 10th March 2010 04:14 PM
help finding bi-metal thermal switches at mouser? lgreen Parts 2 30th January 2006 08:19 PM
Thermal switches joensd Pass Labs 16 22nd September 2003 03:36 PM
Page generated in 0.10449 seconds (75.87% PHP - 24.13% MySQL) with 10 queries
