Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Anyone know how to make transistors?
Old 25th December 2009, 03:20 PM   #1
Test Electrix is offline Test Electrix  United Kingdom
Default Anyone know how to make transistors?
Apparently it's quite possible to make your own transistors, anyone here done this? There was some books printed in the 50s on how to do so, not much showing through google searches at the moment though I'm really hoping something turns up
Old 25th December 2009, 05:37 PM   #2
jcx is offline jcx  United States
FET Transistor Homemade From Cadmium Sulfide Photocell.
http://www.andaquartergetsyoucoffee....eriments-i.pdf
I don't know if these worked but should provide search terms
Old 25th December 2009, 08:26 PM   #3
Cheers at least there's some info around at least! Must be more lying about...
Old 25th December 2009, 08:49 PM   #4
wakibaki is offline wakibaki  United Kingdom
Banned
How to make transistors is well known, but as for making your own, with any kind of repeatability, no. You might be able to cobble together something that would produce amplification by bodging together some existing components into a FET, but you need pure crystalline silicon of a high grade to start with to make a BJT. I don't see how you could make this at home. Of course there are other materials such as germanium or diamond and more exotic ones like gallium arsenide, but I don't think these are necessarily any more accessable or easy to work with.
Any FET you make will only have the same kind of appeal as a crystal radio, although this is not to be dismissed, it's nice to see simple principles demonstrated. I couldn't get the black strap iron diode to work, I had to go for a germanium one.
If you had a wafer, creating a mask on it and diffusing some dopant might be doable, but I'm not sure you could really claim to have made a transistor even then. Making a triode valve is more reachable. You don't see people wearing masks in films of valve factories like you do in semicon fabs, although maybe they do now...
w
Old 25th December 2009, 10:39 PM   #5
Damon Hill is offline Damon Hill  United States
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
There's some fellow in France who makes all of his own tubes, completely. Do a search on Youtube under "hand making vacuum tubes". I was amazed by his craftsmanship; appears to be all triode devices.
YouTube - hand making vacuum tubes Part 1
Making semiconductor devices seems to be a challenge, but some bright and determined person may be doing it. Vacuum state technology is obviously simpler in both principle and practice.
Old 26th December 2009, 12:31 AM   #6
poynton is online now poynton  United Kingdom
poynton's Avatar
I had an old copy of "Wireless World" from around 1954 which showed how to make a point contact transistor from 2 similar diodes.
IIRC, it was very clumsy and 'Heath-Robinson' using lab stands to hold the parts.
All-in-all, not a usable idea !
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Anyone know how to make transistors?Hide this!Advertise here!
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 12:08 PM
Best transistors YUTK Solid State 1 20th May 2005 05:16 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 02:24 PM
transistors lemondog Swap Meet 5 1st March 2002 08:05 PM
