| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need to replace some Toshiba 2SA1962 and 2SC5242 outputs
and I see that Fairchild has these for less money. I don't have any experience with these under the Fairchild brand. Should I skip them and just get the Toshibas? Thanks |
#2 |
hello.
if i need it for service i would use the original transistors on principle. (except the hifi gear isn't worth the money to repair it) greets |
#3 |
I've never had a bum Fairchild device, but the Toshiba devices are available from Mouser.
#4 |
I can get the Toshiba devices at Digikey.
While looking them up I ran across the Fairchild devices. The ones below are what I'm referring to. While the data sheet uses two numbers for each transistor you will notice that the pic shows it stamped with the Fairchild logo and the Toshiba number. I was just curious if anyone has tried them. The price is right but not if they don't hold up or meet up to Toshiba specs. http://search.digikey.com/scripts/Dk...=2SA1962OTU-ND http://search.digikey.com/scripts/Dk...=2SC5242OTU-ND Last edited by glen65; 13th December 2009 at 03:23 AM. |
#5 | |
As far as I know fairchild is manufacturing these japanese trannies under licence, the japanese have a vast advance on semiconductor manufacturing and under a deal with american companies have transferred some of their knowledge and knowhow. Manufacturing equipment was provided too by the japanese, so when buying fairchilds you practily getting japanese transistor manufactured in the US. There shouldnt be any problems with the fairchilds. |
#6 |
Thanks for the replies.
I have used plenty of Fairchild devices before and haven't had any problems. However I haven't used anything from them larger than TO220 case. This is a bit different animal and I was just curious if anyone here had any experience with using these. |
| Who still makes P-type Power Mosfets? (RIP Fairchild) | len_scanlan | Parts | 9 | 1st September 2009 02:33 AM |
| Mounting power transistors | loovet | Pass Labs | 6 | 29th October 2007 09:53 PM |
| Power transistors for DoZ? | bezobraznia | Solid State | 2 | 5th February 2005 01:05 PM |
| SGS power transistors | hifiboy | Solid State | 0 | 4th October 2004 07:44 AM |
| Stasis 3 Power Transistors | Roscor61 | Pass Labs | 1 | 18th May 2004 09:00 PM |
| Page generated in 0.07973 seconds (76.05% PHP - 23.95% MySQL) with 10 queries |
