Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th December 2009, 02:09 AM   #1
neutron7's Avatar
Default Can an LM337 "sort of" work?
I have built a simple LM317 / LM337 bipolar power supply (from a half wave doubler) the transformer had a spare 8v tap and i needed a bipolar adjustable supply to power a roland GK guitar pickup preamp
The circuit is basically the datasheet not unlike, well exactly the same actually, as after the resistors and coils on the twisted pear lcbps_schematicversion but with wave rectification (2 diodes give +- 10.6 volts from 8VAC input)
it is adjusted with 5k 21 turn trimmers, the same ones in fact.
anyways the positive side is perfect, the meter does not budge from where i adjust it to and i cant see any AC on the scope even at the most sensitive scale.
on the negative side there is a ripple that looks just like the input except the DC level is varied by the trimmer. the 337 does not get hot or anything, and there is high (megohm range, but not as high as the 317) reistance between the pins. (oh and with a very small cap on the output the bottom each cycle of the ripple is accompanied by a nice high frequecy oscillation)
is it just a dead regulator? im a bit annoyed because it was my last one
Old 12th December 2009, 03:02 AM   #2
MJL21193's Avatar
How much voltage are you looking for after the regulators? You may not be allowing for the regulators dropout voltage (I can't seen to find it for the LM337 but would be around 2V?). The reg might be fine, just not getting enough voltage.
Old 12th December 2009, 05:23 AM   #3
neutron7's Avatar
the voltage is - 10.6v and the voltage i am trying to get is in the range of -5 to -8 v, even when i adjust the trimmer so it is only putting out 4v or so it still has the ripple. the positive side works perfectly
Old 12th December 2009, 05:26 AM   #4
Enzo is offline Enzo  United States
ANy chance you overlooked the different pinouts between 317 and 337?
The tabs are active, any chance either tab is connecting to someplace it ought not?
Old 12th December 2009, 05:53 AM   #5
neutron7's Avatar
no not at all, i have not put a heatsink on them yet, it is only supposed to power 3 dual opamps. the circit has been checked and checked again, right now it is just powering LED (which is on the board to show its working) the in outs are carefully set up, i spent ages on the board and it is right.
reason everything is so fat is because its only a 1/2 oz board, used pulsar toner transfer
Old 12th December 2009, 06:43 AM   #6
Are you doing the measurements with a load? Rember if these regulators arn't
supplying some minimum load and I think it's about 5ma they will nor work right.
A 1k resistor across the output would be enough of a load to check if this is the problem.
Old 12th December 2009, 04:20 PM   #7
neutron7's Avatar
Yes they have a small load, a resistor and indicator LED on the board, 750 ohms.
Old 12th December 2009, 05:00 PM   #8
pjp is offline pjp  India
pjp's Avatar
That is a very unusual looking board! What did you use to draft it ?
Last edited by pjp; 12th December 2009 at 05:00 PM. Reason: removed unnecessary image link
Old 12th December 2009, 05:29 PM   #9
I just looked at the data sheet on the lm337. In your case it may need
a full 6ma of load current. I don't think the led and 750ohm will pull that much.
You might try just shorting the led out and try that.
Old 12th December 2009, 05:59 PM   #10
neutron7's Avatar
Ok i just replaced it, after going out in the freezing cold to get some more, which i didnt want to do
and everything is fine now.
Thanks for the suggestions.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
How Do "Heat Fins" Work In a Vacuum? DaveMcLain Tubes / Valves 7 11th April 2008 11:49 PM
How can I add a "Digital In" to my current cd player ? (Make it work as a DAC ) b_online Digital Source 2 20th December 2007 10:52 AM
Randy Slone "Fig 11.6" amp, modded: will work? tcpip Solid State 85 29th May 2007 10:31 PM
Will this work? "Mixed" 300B PPP IT ppereira Tubes / Valves 4 24th April 2004 05:29 PM
Page generated in 0.08702 seconds (84.26% PHP - 15.74% MySQL) with 10 queries
